24v dc fans
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
One of my ongoing part time projects is ventilating this old house.
I have an almost adequate system at present, but recently acquired two 24v centrifugal fans.
They have four wires 1 pos 1 neg 1 input for speed control and 1 output for a tachometer if desired.
May be I've got it wrong?
So asking here for advice re wiring/controlling them.
Ideally with speed control, maybe even a humidity switch.
You really need a device data sheet or at least make & model, there are way too many variables otherwise.
Would this help?
Many fans will work at a lower voltage, at a lower speed, and thus much more quietly. In the old days it was reasonably common to run 12v computer fans at 7v (7v was an easy voltage to get in a computer); you should be able to run these fans at 12v nearly silently. Perhaps that is helpful?
It's an off-brand copy of a Papst fan, full datasheet here: https://www.mouser.co.uk/datasheet/2/120/ebm_papst_R1G190AB2702-1880174.pdf
Speed control is easy enough, it can be controlled via a variable voltage in the range 0-10V on the yellow wire - that's a high impedance signal rather than power so a simple pot would allow you to set the speed. Alternatively pulse width modulation, the datasheet has an example drive circuit from logic levels. That gives a series of pulses at a rate of 1-10kHz, the proportion of the time the input is at "high2 voltage sets the speed. That tends to be a more appropriate method for computer control. You'll need to arrange either signal from the controller according to what you have in mind.
Thanks, but these fans won't run even at 24v without a third input.
Thanks, that's the info I need.
I was reticent to apply a DC voltage as I wasn't sure if it had to be PWM.
So just to confirm before I do something stupid, if I apply a DC voltage less than 10v to the yellow wire the fan will go and if I insert a 10k pot I can adjust?
