UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: 18 Feb 2017, 18:41
Offline
Settling In
Has thanked: 40 times
Been thanked: 32 times
I couldn't find much information or reviews before taking the plunge and buying these tools, so here we go...
No idea how to get photos the right way round, but click for full size and all will be revealed!
Up top is the String Inlay Scraper, with the Inlay tool on the left and the Compass centre (with pencil holder) on the right.
I've never done any of this type of work before, but as usual the Veritas instructions are easy enough to put into action.
First, set the Scraper to the width of inlay required - no fiddling about required, just pop the groove blade (which we'll meet again later) underneath and tighten up.
I then cut a strip of veneer (roughly 1.5mm) on the bandsaw from an offcut of Ash. Not the best material to work with, I suspect, but I'll hopefully be picking up some Holly soon enough.
The instructions for the Inlay Scraper recommended building a jig for batch work and I can rarely resist the temptation to add another jig to the pile...
The Scraper is used just like a cabinet scraper, with the exception that it "bottoms out" on two skates either side of the blade when the depth is reached. Not sure that ply is the ideal material for my jig as the skates are digging in a bit.
With the veneer scraped level and to size, it was time to get the Inlay Tool out.
This comes with a slicing blade (for trimming veneer into strips) and a groove blade (for making grooves in the workpiece). They're interchangeable but it's a bit fiddly, and I can see myself hunting for the screw/washer combo amongst the shavings on the floor at some point. Either that, or shell out for an extra cutter head and have a dedicated one for each operation. Here's the slicing blade in action -
Yep, I built another jig to hold the veneer in place.
There's a couple of detachable rods that line up alongside the cutter head; a very useful touch as you can introduce the blade lightly as they ride on the jig's fence.
Stringing sorted, time to lay out and cut some grooves...
Share on Facebook Share on Twitter Share on Digg
 Profile
PostPosted: 18 Feb 2017, 18:57
Offline
Settling In
As mentioned, changing the blade is a bit fiddly -
I faffed about for a bit using the pencil holder to layout a design, but the posh Veritas bookies' pencil wasn't up to much and I couldn't be bothered to head indoors and fetch a decent one...let's just say that the layout option is probably necessary but I was too keen to make grooves!
The groove blade works with a sort of push/pull technique - pushing defines the groove and pulling scrapes it out. I got nice, clean, well-defined grooves with no tear out or fluffy edges first time round. Very impressed.
At was at this point that I decided to quit while I was ahead, hopefully tomorrow I'll get time to let the stringing meet the groove and report back...
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Parf Guide System Review
in Jigs, Tips & Shopmade Tools
DiscoStu
14
1682
02 Mar 2017, 17:33
Poor man's Scary sharp tool Sharpening system?
in Buying Advice | Tool Reviews
MrDavidRoberts
22
919
06 Jun 2017, 16:15
Inlay box
in General Woodworking
Trevorturn
17
440
17 Aug 2017, 16:54
End Grain Inlay
cowfoot
3
332
05 May 2017, 14:19
Metal Inlay
Dokkodo
9
391
05 Aug 2017, 10:49
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
phpBB SEO
