Multiple machines just for convenience...
LancsRick
30 Dec 2011
Lancashire
I really like my RAS, always have. I'm also growing to like my table saw more and more, and no longer take the view of it being a poor relation. I could never see myself just having one saw though because of the time taken to change blades. My RAS has a 60T 250mm blade on it, and the table saw a 16T 210mm for rips. Do other people share this view, or are some table saws very quick and easy to change blades on? It's a 5 minutes work to swap my TS blade, which adds up unless you're able to group all your cuts.
i dont disagree with what you say. the other major consideration though is space
What Marcros said
Plus it very much depends on whether you're producing for a living or retired and just faffing about like me where changing a blade is also an opportunity to clear the sawdust accumulation. :lol:
Bob
What kind of table saw do you have? And what kind of wood/thicknesses are you dealing with?
I tend to keep a 40T, high quality general purpose blade on my Wadkin 10" tablesaw. It give a fast, clean cut both ripping (up to around 38mm thick hardwood) and crosscutting (up to about 75mm thick hardwood). That's with a 3hp (2.2kW) motor though.
I'll change to a specialty blade if I need to, and on most tablesaws I've used blade changes take about... 30 seconds?
If you have the space though, I'd always recommend having tools dedicated to a specific job. That way you spend more time making stuff and less time fiddling with machines.
And if you're batch processing often it's useful to have two different setups for the same 'job' that mean you're not changing setups all the time.
I bought my new table saw with a view to get rid of the SCMS but couldn't do it - just the hassle of faffing with it all. I trick I definitely missed is my blades have different kerfs so messing with the riving knife makes a cheeky swap a pain.
I only have a single garage, so I'm definitely sacrificing precious space for the luxury.
The TS I've got is an Elektra Beckum PK200. Lovely machine, but changing blade is 4 screws to remove a section of the table, a spanner to remove the blade cover, then I can get at the blade, and reassemble in reverse!
I barely use my TS now and do most stuff with a tracksaw and SCMS and occasionally the bandsaw, but my TS still comes in handy if i have a lot of narrow rips to do, which happens every once in a while. Most of the time, it is shoved away in a corner taking up valuable space that i could utilise more efficiently. So with that in mind, i am thinking of moving it on and buying a small portable site saw that i can hang on the wall when not in use. Trouble is that i am having a hard time justifying the £500 i would need to spend on a decent one, just to use now and again.
