found this interesting article on Record Paint:
PAINT COLOUR
The planes with a painted finish were advertised in catalogues as Record Blue but the shade did vary over the years. The spokeshaves which had their numbers prefixed by 'A' were made of malleable iron and painted red. Cellulose paint was used pre WW2 and subsequently stove enamel. The name Record on bench plane lever caps was highlighted in orange throughout most of the production years but was omitted from the early 1990's. Early block planes prior to WW2 also had Record highlighted in orange on the lever caps. It is said that the choice of the original blue came from the outer ring of The Royal Air Force roundel, such as in an archery target.
The supplier and manufacturer of the paint to C & J Hampton was R. J. Stokes & Co. Ltd, Sheffield. The original paint colour was known as Roundel Blue, then Hamptons Blue and later as Record Blue. The reference number for this paint is "BS 110 Roundel Blue". The BS refers to British Standard and is one of the colours from the very old BS381C range. Originally the paint was a traditional solvent bourne stoving enamel. Over the years the paint was re-formulated several times to reduce the solvent content and work at lower oven temperatures. For the last number of years there were two separate paint lines. One was an Epoxy Polyester power coating and the other a Waterbound dip coating, both of which were still stoved. This virtually eliminated the solvents in the paint. R. J. Stokes and Co. Ltd also supplied the orange paint for the highlighting of Record on the lever caps of the hand planes and block planes. The red paint on the spoke-shaves and the green paint for the Calvert Stevens Plane No. CS 88. Needless to say all this paint was developed and produced in Sheffield by
R. J. Stokes & Co. Ltd.
I would like to thank Mr James Stokes for all his help and time in getting this information for me.
The R. J. Stokes & Co Ltd
In the United States the federal spec number for Record Blue is FS 595 15056. This number is a part number for Irwin Tools (US) Not sure if this is the later lighter blue colour that was used by Record/Irwin Tools.
I would like to Thank Mr Paul Hook, Virginia USA for this information.
