Hello everyone,
I'm reaching out to you today because I'm facing a bit of a repair challenge with my Kity 637 planer-thicknesser. After identifying a problem with the ball bearing, I'm getting ready to replace it. However, before I can go ahead with purchasing and replacing the bearing, I need to dismantle the shaft it's mounted on, and I must admit I'm not entirely sure of the best way to proceed.
I'm therefore seeking your advice and tips on:
Safely and efficiently dismantling the shaft's screw (photo attached). If you have any specific recommendations on tools to use or particular precautions to take, I'm all ears.
I've tried using an Allen key and a lever arm, applying penetrating oil + heating, but nothing moves, both clockwise and counterclockwise.
Knowing that I've already heated the screw, given a few punches with a drift pin. Attempted to turn in both directions...
Dentifying and finding the right bearing for my Kity 637.
If you've ever had to make this kind of repair or if you know of any resources, tutorials, or reliable parts suppliers, your help would be greatly appreciated. Additionally, if you have any general advice on maintaining this machine or recommendations on practices to ensure its longevity, I'm all ears.
Thanks in advance for your time. I look forward to your responses and advice.
Best regards, Rémi
Best regards, Rémi
![Axe[1].jpg Axe[1].jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/159/159059-Axe-1-.jpg)
![IMG_20240322_171138[1].jpg IMG_20240322_171138[1].jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/159/159060-IMG-20240322-171138-1-.jpg)
