Lathe modification
pat from Marck
26 Feb 2023
Marck France
New legs for new working hight and stability. One of my legs had rotten away due to rust and was slowly curling up at the base causing stability problems. Secondly the hight of the lathe was to low for me causing back problems especially when hollowimg out. So came up with this solution. Three bits of angle iron into bottom half of a pyramid shape to match the inside bottom half of the lathes legs then attached buy six locking nuts. Then added two adjustable feet to the underside. Then repeated at the other end.
j
