justinpeer
Hi all,
I've been an occasional hobby woodworker for years but for the past decade or so, I've mostly just been fixing things and making stuff around the farm rather than doing more interesting or fine woodwork. I have a modest workshop and my sharpening gear has been a diamond plate and stones, a King 1000 grit and Norton 4K and 8K, with a Nagura stone and leather strop, shown below, which has worked for my occasional use and modest collection of chisels and plane irons.
A little while ago, a friend's father passed away and I was gifted his old Coronet Major Lathe with accessories and a box of turning tools and an old combination bench grinder. I've built a stand for the lathe now but it needs some proper clean up and rust removal. I have new belts for it as the old ones are well past they're best. I should add that I've no experience turning anything yet.
The grinder had no rest and the water wheel wasn't really much use. I picked up the veritas tool rest and bought a new white wheel for the high speed side but, despite hours of YouTube research and experimentation, it still doesn't balance that well. I decided that I'll probably use it as a rough grinder in the garage and, if I can get an adapter made to fit, convert the slow speed side to high speed as well and that can be used for cleaning up old vehicle parts etc as I'm rebuilding an old MX5.
Given the amount of cleanup and sharpening ahead, I decided I need a proper grinder and, after more research I think I've decided to get a grinder with CBN wheels (probably one to start with and another as funds allow) which should do both woodworking and turning tools, much inspired by @Derek Cohen (Perth Oz)
So, grinders then. Slow speed seems the most suitable option and the options seem to be the Axminster grinder at £210 plus the cost of wheels at £140-£170 each so about £370 if I go with a single 180wheel and add a second later. Then there's the Dictum with a 180grit wheel included at €400 or Hope Woodturning with their grinder and a CBN wheel at £385.
The Dictum and Hope grinders are 400w (½HP) whereas the Axminster is 900w (1HP) and I'm wondering if that's really going to make a big difference and if anyone has suggestions either on an alternative grinder in the same price range or whether any of these are significantly better than the other in quality. I've had an eBay search open for Creusen grinders for months with nothing coming up, not helped by being down in Devon when anything that does come up always seems to be collection only from the north.
I should add that I did look at the linisher options from Sorby and Axminster but they're even more expensive and I like that with the CBN wheels I basically don't have to replace them ever given the level of use I'm likely to have.
Be grateful for your thoughts.
