A antifoul2020 Established Member Joined 5 Aug 2021 Messages 76 Reaction score 14 Location Scotland 11 Dec 2023 #1 Is this triangle telling me that my battery is flat Your browser is not able to display this video.
artie Sawdust manufacturer. Joined 12 Jan 2015 Messages 3,056 Reaction score 1,395 Location Norn Iron 11 Dec 2023 #2 yes. Charge the battery and try again. E 01 is the fault code for a flat battery. Here's some more you might encounter. And a link to some useful info. E-01: Undervoltage of power supply – battery is low. Solution: Recharge your battery before turning the heater on. E-02: Overvoltage of power supply – voltage is too high. Solution: Reduce the voltage to 12 volts. E-03: Glow plug fault – ignition plug failure. Solution: Check glow plug and leads (replace if necessary). E-04: Fuel pump fault – fuel pump broken/ not working. Solution: Check the fuel pump’s getting power – replace if necessary. E-05: Overheating. Solution: Check the heater’s air intake and exhaust for blockages
A antifoul2020 Established Member Joined 5 Aug 2021 Messages 76 Reaction score 14 Location Scotland 11 Dec 2023 #3 Many thanks for your reply And terrific information
