In answer to your questions Chas;
CHJ":fqn7vys2 said:
1. How thick was Zebrano stock when you worked it
I found some Zebrano pen blanks and tried to cut a nice thin veneer, but I was too idle to change my bandsaw blade, so I had to thickness the resultant strip on the pillar drill between a sanding drum and a clamped pine block. I stopped when it looked about right, as you can see the strip ended up at 0.75mm.
CHJ":fqn7vys2 said:
I made a quick and dirty clamp to hold a steel rule down firmly on the Zebrano so I could cut a couple of 6mm wide strips without slipping. I cut them diagonally to make the most of the grain/pattern when wrapped around the ring.
After reading various bits and bobs on bending and watching a video by Ian Norbury I thought it didn't actually look as difficult as I had at first imagined. I put the strips in water overnight, then next day I held a bent stainless steel rod [16mm] in a vice which was then heated with a blowtorch. Before I started bending one of the wet strips I had a go with one of the dry triangular off-cuts, it bent so easily and well that I wished I hadn't bothered wetting at all. You can see it on the left in the first picture.
CHJ":fqn7vys2 said:
The curve of the bent strips [I only used one] was slightly tighter than that of the ring. Before bending I cut a long taper on either end with a small flat chisel, these then 'mated' when in place. I used some past-it Zap-a-Gap to stick the Zebrano to the ring, and the tapers to each other [splice the ends].
The actual TURNING came right at the end, after the glue had set I mounted the ring on a softwood mandrel, in the right orientation so the strip wouldn't unwind, then took the very lightest skim to get rid of any squeeze-out and to flatten back the join.
Very fortunately, the pattern of the wood makes it very difficult to find the join. The external surface of the ring was finished with friction polish, the sides were wet-and-dry'd to P1000, the softwood mandrel was skimmed down a bit and used as a rotary hone to polish the inside with Solvol Autosol. The sides were polished too.
Sorry for the long-winded post, but you did ask.
