ratkinsonuk
Too cluttered, or would be OK?
MattRoberts":37fkc1yl said:Looks very similar to my single garage 5m x 3m. I fit my tablesaw in there fine, albeit more against a wall rather than in the centre.
I can share my plan / pics if it helps?
SteveF":2q574z6m said:put the drill press in-line with chop saw
if you can get the height right so you can use the worktop for both
Steve
ratkinsonuk":2a6a2qlh said:Cheers Steve. My original sketch had the drill on the end of the chop saw station, and that's probably where it would eventually end up depending on how things pan out. My ineptitude with the web version of SketchUp lead me to just dropping it 'wherever' for the purposes of the initial design.
A side question - has anyone bought one of the cheap £25 copies of SketchUp Pro from eBay and do they work or is it a con?
Cheers.
MikeK":1t3avml9 said:I think the eBay versions are cons and would stay away from them. Is there any reason you aren't using the free SketchUp Make? This has all of the features I could ever want in a free program. I use AutoCAD at work and cannot justify the cost of SketchUP Pro.
nabs":2fa3h8v0 said:you can still get the 2017 desktop version of Sketchup Make. As far as I know this will be available indefinitely, but they have no plans to do any more updates to it (only the Pro full client and web-based Make will get updates from now).
https://www.sketchup.com/download/all
