hrk
I need to upgrade my dust extraction in my double garage workshop. Its mostly for power tools (plunge router, track saw, mitre saw etc). I will be getting a router table soon.
I currently have a trend T30 which I got on ebay and its rubbish - the hose barely sticks to your hand. My home VAX has miles more suction.
I'm looking to sell this and get set up something a bit more substantial but I have some questions which I'm hoping you guys can help me with.
If I get two of the SIP 01929 extractors can you double them up through a Y connector then into a cyclone? will it be substantially more powerful than a single one? could I even go up to 3 of them in the future?
what effect do different hoses make?
is it best to keep it as wide as possible and reduce at the end or the other way round? the SIP has 100mm hose which will need reducing to 63mm and even smaller for some tools.
Would 8m of 63mm single hose be too long from the cyclone/extractors? If I could get this length I would be able to have my extractors outside in a waterproof cabinet.
I willl also add a passive air filter at some point and I always wear a respirator when cutting.
Any input appreciated!
thanks
thanks
