thomaskennedy
as usual a question
maybe one day i will say something usfull like "this is how you make money grow on trees" but untill then....
i have made the top of a tv corner unit (some of you will have seen the picture i drew of it) but it is quite big, i have quite a few clamps but they are all too small, and i cant find a big enough clamp,
so i was thinking, oh ill just get a band clamp :?: (dunno if this is the official name) but in axminster etc. they only had them with 4 corner bits where as i need 6 (2 at 90 degrees and 4 at around 60 degrees)
so then i though i wonder if one of those strap things will work?
heres what i mean by strap things
http://www.axminster.co.uk/default.asp?part=KRA983590
would thse do an effective job of holding a 70mm wide, frame around the outside of the top?? its connected with biscuits by the way!
Tom
Tom
