RogerS
The Xtreme Xtension is a superb example of design over function IMHO.
At least as far as using it in a WoodRat goes. The additional length makes it unusable. Every router cutter protrudes below the router plate making plunge routing impossible or doing any of the things that the 'Rat is great for.
Adding the two raising plates allows me to just about put my shortest 1/4" cutter in and use it with any degree of safety and usefulness. None of my 1/2" cutters will fit to allow 'normal' operation.
The diameter of the Xtension means that you cannot get it through the NS groove and so you're forever messing around with watching the plunge depth or fiddling with readjusting the cutter (when you find one that actually doesn't foul the work before you even start plunging).
I don't think I'm missing anything here in the set-up. But always willing to learn especially if there is a solution.
So far really disappointed since I was getting very fed up with the hand gymnastics needed to (a) hold the cutter at the right depth with hand one (b) rotate the router spindle with hand two so that (c) I can then hold in the locking button with hand three and with (d) hand four use the spanner.
:evil:
In this set-up the Xtension is truly duff and one of my most disappointing purchases.
Router is a DW625
:evil:
Router is a DW625
