Craigclose1991":35p07iuw said:
Hi
I have just recently purchased the xcalibur table saw and I’m in the same position regarding the wiring have you got the saw up and running ? If so could you send me as much detail as possible (pics would be nice) the whole electrics thing is driving me mad!
Thanks in advance
Craig
Moonsafari69 got it spot on in his response.
The Xcalibur can't operate from a 13amp socket, it will trip the MCB every time you start it up. When I was waiting for delivery of my Xcalibur earlier this year, I had an electrician review my garage wiring. He recommended that to avoid overloads I should run a new (second) supply from the house to an additional (new) consumer unit in the garage from which the 16amp supply could be run to new commando sockets. The problem was that the existing cable from the house to the existing garage consumer unit would be overloaded with the addition of my new table saw. Also, the existing garage consumer unit only has two breakers, one for lights and the other for the ring of 13amp sockets (I'd originally assumed that I could just change the consumer unit for one with capacity for additional MCBs but, as he said, there would be an issue with overloading the existing cable feeding it from my house).
When the saw arrived, with the electrical installation complete, I simply purchased a 16amp commando extension lead from Toolstation, plugged it in, and I've been up and running without issue.
As I had him install a couple of 16amp commando wall outlets, I've also added a fairly capable MIG welder which also required a 16amp supply.
Unfortunately by law, as a new circuit was required (even if my existing workshop consumer unit had had the spare capacity) the wiring had to be signed off by a suitably qualified electrician.
If you have any specific questions about this I'll happily try to answer them.
Jerry
