Nailer
I Picked one of these up from woodford on saturday and with the help of a fellow forum member Frank got down to the business of putting it together,which took a couple of hours and then about another hour or so to fine tune the saw.
It's basically a copy of a murrican "Contractors Saw"...i'm assuming Delta as the 806 is a Unisaw clone (but don't quote me on it as i'm not sure).
It's well built and heavy so a mobile base is a must if you plan on moving it at all,also it comes with a bessimier alike fence but no micro adjustment i'm afraid.
The max cutting capacity to the right of the blade is 30" although it does say 50" on woodfords web site....this is a little misleading but it wasn't to much of a problem for me as i don't have the room for such long fence rails.
It's got a 1/12hp induction motor which in use is quiet but i will say does bounce about a bit but i think this is down to the drive belt being either new or cheap...if it doesn't settle down with use i'll see if i can get a better quality one or even try to sort a link belt for it.The actual fitting of the motor is a bit fiddly on your own so is ideally a two person job.
The height and tilt adjustment is very smooth with good size handles (which lock off) with very little if no backlash at all.
The main table is flat and the extension wings....after a few minor adjustments with a wooden block fitted flush.
They also fit NVR switches now as standard you'll be glad to know.
I haven't had chance to have a proper go using the saw so cannot comment on the acuracy just yet but there's no reason why it shouldn't be........but on the whole very pleased so far.
oh aye almost forgot it'll take a dado
Anyway here's some pics
*UPDATE*
I fitted a Power Twist Link Belt to the 804.....at £35 a bit pricey for a belt :shock: but i have to say worth every penny
I must admit i was a bit doubtful how much difference a belt would make.......but as they say seeing is believing
The vibration is virtually non existent now.....i can now balance a penny on the ends of the fence rails where there was no chance of that before.
The noise has also been reduced dramatically.....i'd say 50% atleast if not more
An even more happier woody than i was before 8)
Thanks to Noel & Jorden for the info regarding Link belts
*UPDATE*
