Worst things about your current workshop!
Adam
10 Sep 2003
UK
1) No natural light
2) Small
3) Too much moisture to keep "project" wood
4) So close to the neighbours I worry about how much noise I make
5) Too hot in the summer
And.....
6)
7).....
Pete W
31 Jan 2004
London
Plenty of shortcomings at the mo', although most can be remedied.
1. Flat roof needs repairing/replacing - it leaks!
2. Single power socket - needs a zillion more
3. Limited natural light from a single small window
4. Have to share with a fridge/freezer and washing machine/dryer
5. No storage - first project is to build some workshop cabinets & shelves
6. Cold and damp (see points 1 & 2)
7. Because it's an attached garage and in a residential area, noise will be a limiting factor
Adam
10 Sep 2003
UK
Come on Pete, 'tis supposed to be a list!!!
Adam
6. Flat roof needs repairing/replacing - it leaks!
7. Single power socket - needs a zillion more
8. Limited natural light from a single small window
9. Have to share with a fridge/freezer and washing machine/dryer
10. No storage - first project is to build some workshop cabinets & shelves
11. Cold and damp (see points 1 & 2)
12. Because it's an attached garage and in a residential area, noise will be a limiting factor
So everyone else thats....
13.
14.
15.......
Signal
23 Dec 2002
13. 200 quid a month is just too expensive
14. 3 Miles up the road make it to easy to think of an excuse not to go
15. Pain in the but landlord
16. Roof, ha!
17. Insul what?
18. Threat of death from exposure during winter months
19. Its to small
Signal
Alf
22 Oct 2003
Up the proverbial creek
20. The floor slopes in all directions
21. Sometimes all that natural light flooding in is just too much...
22. It's got a Maxi in it :wink:
Everything else has been pretty much covered. Too cold in winter, too hot in summer, the worst possible conditions for storing wood etc etc It's a hard life torturing wood...
Cheers, Alf
Adam
10 Sep 2003
UK
23) No running water so I have to clean all glue/brushes in the house
And just remembered theres a pot of glue I was supposed to bring in and clean last night. <insert word here>
Adam
Adam
10 Sep 2003
UK
Well, it begins with 'B' ..... :cry:
24) It was only after I built it I found polystyrene insulation and electric cable should not touch each other......
25) When angle grinding the excess from a coach bolt on the door hinges, which is red hot, don't let it fall into your boots, 'cos no matter how fast you get those laces undone, its no quick enough
woodshavings
20 Mar 2003
Alton, Hampshire
26) Its got a concrete floor and I did not level it properly
27) I have not installed a collector system
28) My bench & workstation heights are not the same so I do not have a clear run when using the RAS.
29) Its not big enough !!!
A
Anonymous
Guest
31 no sound insulation and so I can't work late as the garage is part of the house :(
A
Anonymous
Guest
I have 1-31 plus
32.There's a giant freezer in the corner
33. All the wifes gardening stuff.........which should be in the shed.
Aidan.
trevtheturner
26 Feb 2003
Herefordshire, UK.
34. concrete floor
35. not enough natural light
36. space taken up by staircase to loft
37. not enough wall space
38. only single door access - 'til I start using the adjoining garage.
But, hey, we all have 'good' and 'bad' things - but we're all well off 'cos we've all got workshops!
Cheers, Trev.
dedee
24 Jul 2003
14860, France
adam
I read about the degradation of the cable before I installed the poly in my workshop & routed all the cable out of the way. I also did an experiment and sandwiched a piece of cable between 2 pieces of poly held with an elastic band. In nearly 12 months I can see degradation at all. This is not a scientific test of course only food for thought.
AndyP
A
Anonymous
Guest
Ahhh As an electrical and electronics design engineer before deserting to lecture for more dosh, I believe I can shed some light on this
The problem is not a degredation of the insulation due to contact with the polystyrene but a build up of heat as there is no air flow around the cable which may lead to failure and breakdown followed by fire. The IEE wiring regs have guidance for this and if they are contravened your insurance will be voided in the event of a house fire caused by the wiring. you have been warned!!!
OK. The 16th edition of the IEE wiring regulations have tables of cable ratings with the default installation method being direct clipped to a wall. The current carrying capacities for single core twin and earth double insulated PVC cables (grey flat stuff) is as follows:
1mm 15A (lighting)
1.5mm 19.5A (lighting)
2.5mm 24A
4mm 32A
6mm 41A
When the cables are placed within (sandwiched and touching) an insulating material such as your poly, then you must apply a derating factor to them as follows:
run length factor
50mm 0.89
100mm 0.81
200mm 0.68
400mm 0.55
500mmm and over 0.5
So, if you have a run more than 1/2m, then you must use cable that is rated for double the current carrying capacity as the derating factor is 0.5.
So 6mm in place of 2.5mm for mains wiring and 2.5mm in place of 1mm or 1.5mm for lighting.
The mains should be wired in a ring circuit (start at fuse and connect to each socket in turn until you return to the fuse again) and protected by a max. of 32A fuse of MCB.
Hope this:
a is not too boring
b is useful
Tony
