gus3049
I am now an ex-kitchen fitter.
In fact I appear to be an 'ex' almost anything you care to name now. After seven out of eight weeks of intensive physio, I can walk and move well but I'm not allowed to lift anything.
Anyway..... in all the years I've fitted kitchens I have only once used a jig for the worktops and I had to borrow that, never did trust these new fangled machines, what's wrong with a saw? Much cheaper too!. I always did them by hand!! It seems a fairly simple joint, just and straight line and a 45 degree turn on the end. One reason is that I like the widest tops I can get as I tended to build the carcases out of 600mm boards and only a few of the better jigs were wide enough. I did dowel or biscuit and bolt the joints of course but that can be done by hand too. You really don't NEED to use the jig.
The attached is the only one I have pic of and it is, admittedly not the best joint I've ever seen (my excuse is that the pattern on the top makes it look worse )but it was done in a hurry with a blunt old panel saw!
Whichever way you decide - happy fitting.
