Worktop Repair
woodshavings
20 Mar 2003
Alton, Hampshire
Help, I'm in trouble! :(
In removing a wash basin from a vanity unit, I damaged the laminate on the front edge of the bowl cut out. I hadn't removed all of the sealant :oops: and this pulled and broke off about 25 mm by 5mm of the laminate as I lifted the basin out. I have some of the broken laminate but it splintered and is not very usable.
SWMBO is not pleased :x :x
Replacing the worktop will be a real problem in matching up the rest of the dressing unit so I am hoping they is some form of repair kit that I can match the colour and fill in the chip.
Any suggestions gratefully received.
Same thing happened to me in the kitchen.
Screwfix do a product listed for worktop joints, you can mix the colours and get a near perfect match, takes a few coats and looks like a repair for ages but it does blend in eventually and is not too noticable.
Colourfill comes in a bigger range of colours than SF joint sealant, you can get it from Woodfit but need to know make & colour of laminate.
Jason
