Workshop Humidity
Nigel Taylor
18 Oct 2020
UK
I must admit that my tiny workshop 11 ft x 8ft inside dimensions struggles a bit with condensation.
the panoramic rather stretches it out
So, I use a small 150W tube heater with a thermostat set at around 7°C to limit the temperature drop. Plus I use a chemical dehumidifier. This keeps the humidity down and stops the worst of the rust.
I have avoided the electrical dehumidifiers based on the fact it will just take up more room. However, I was contacted by Alan with a measurement and control system that can switch a heater and a dehumidifier based on dewpoint measurements.
Hence I wondered what other techniques people use to reduce workshop humidity?
my old workshop was in the attached barn to the 17th century stone built converted water mill.....
draughty as hell and always damp......
all my machines, full set of Wadkin plus 2 metal lathes and 2 milling machines all got one of those old fashioned mains powered hand held inspection lights with an 11watt curly wirly bulb on 24x7 from Sept/Oct untill the last frost etc......all covered with old blankets an Duvet's....
never a rust problem and the lecky bill was not really noticable....
not hard to uncover a machine when needed....
also got sick of bining 15kg rolls of MIG welding wire each spring so the welder got the bulb treatment as well.....worked a treat.....
all the metal machines used a water /oil mixed coolant and still no rust....
It's an interesting one as I live in what has to be one of the dampest places in the UK, Aberdeen. I have an outhouse which is so damp materials will go mouldy, however my shed/workshop has no issue with rust at all. The shed was built 5 yrs ago and is a raised wooden floor then a framed structure with house wrap, and a larch cladding rain screen.
My thoughts on why the two are different are:
- workshop has lots of timber in is so I think it acts rather like a cigar humidor perhaps?
- no concrete floor in the workshop which is where I think a lot of the moisture comes from in the out house.
- workshop has excellent rain protection so no penetrating damp.
I do feel that workshop moisture is more than just a temperature/environmental issue else both my unheated buildings would see similar behaviour. I'm trying to improve my outhouse at the moment and I'm thinking of a floating floor over a dpm to try to keep the moisture from the floor out.
