Workbench Tension/Vibration
Also, it looks like most of it is made from quick grown pine? that may well be a lot of the reason it feels like that.
You've done the obvious intuitive things. Did the soft mountings have any effect at all?
In dealing with vibration problems in engineering it is useful to analyse the directions and perhaps the frequency of vibration. So try to answer the following questions
- Is the main component of vibration along or across the bench? Does it vibrate as much when you plane across the bench as it does when you (as normally) plane along the bench?
- Is it the same on the been top and on the legs?
- Is the vibration mainly in the top, the apron, the legs or the stretchers of the bench?
- If you push the bench left to right or back to front do you feel any racking (motion of the top relative to the feet, making the structure into a parallelogram rather than a rectangle).
To answer these, whack it hard with a mallet in different directions (with a scarp pice of wood in the way to prevent damage) and use the fingertips of your free hand to sense the vibration on different parts of the bench. Fingertips are very sensitive to vibration, and you should be able to isolate any joints that are not rigid enough, since the vibration will be strongly damped across them.
As others have said, I think it is likely that there is some lack of rigidity in some part of the structure. Better to try to find out where before you go adding bracers everywhere.
If you can answer these questions, the solution may become obvious.
That would work":360rz2fo said:
I would have gone for deeper aprons (and deep for the whole length of them rather than cut out)
Mine is perfectly stable without any aprons.
One thing I did with mine was to put the (five inch) rails at different heights from front to back, with the shelf in a rebate on the top of the front rail to a quadrant fixed at the bottom of the back rail. Their being in different planes helps stop (to borrow Mike G's (iirc) word) parallelogramming. :D
Osvaldd":37xsxrw8 said:
... you can stand on it and dance, jump up and down all night it will not fall apart. .....
Ditto B&D workmate, but it still vibrates if you saw/plane on it.
Actually you get similar if you try to saw/plane on an ordinary lightweight table. It's not the mass it's the stiffness - if you brace it against a wall you can eliminate the problem.
Jacob, its not loose or rocking back and forth like a workmate, I know that feeling, I have a workmate, from LIDL :D . As I said, it's the opposite of loose, its too tight somewhere and it resonates like a drum skin or a guitar string when you strike it.
Well I dunno!
Maybe you've just got to get used to it.
Planing endgrain is difficult if you aren't used to it. Try sharp blade very fine set, experiment on the end of wide board (6"+) but thin (10mm or less) to get the feel?
I am listening to exactly what you are saying. It is surprising since looking at the bench it seems fine with no obvious thin joints. A simple way to see if frame stiffness is actually the problem, and where it might be, is to temporarily put diagonal bracers on the front/back/sides, held by clamps.
Can you temporarily take off the top and see if the fram has the same problem on its own?
If it is really a resonance problem then you may have accidentally hit a resonance mode of the structure when planing. But that would be a huge coincidence but doesn't square with the whole bench having a rubbery feel. That indicates a lack of stiffness in one or more joints, and you have to identify where this is. It is unlikely to be a leg or stretcher as these are pretty massive.
While you are testing for this, I suggest you remove the soft feet, but use wedges to ensure that all four feet have solid contact with the floor.
Keith
Osvaldd":31ie1ifj said:
Few weeks ago I finished my workbench. Its an English style bench made with construction grade softwood, 3" top, 4" thick legs, two shelves, tool well, it’s 70" long and 30"wide, it weighs a ton I can barely lift one side. It's all mortise and tenon joinery.
I messed up somewhere, the bench feels super solid yet tense, like a drum. If I hit the top or the sides with a hammer or even a fist it resonates and vibrates, planing something difficult like end grain is a nightmare... :evil:
At the top of the legs, is there a top rail, that goes from front to back, supporting the top all the way across?
Bod
How wet was the timber when you built it?
Or put differently, how long did you store it before you started building?
The reason I ask is that it may have shrunk considerably and the screws are now holding the joints fractionally apart. Can you reset these?
Bod
yes, there are bearers on each side.
unfortunately the top is glued to the front apron, and the apron is glued to the legs. I will loosen the screws though.
some of the timber was pretty damp when I got it,but It obviously wasn't green wood. I stored it in the shed for about 3-4 months before I started working with it.
If this is a resonance problem you can check it out as we do in instrument building. Your workbench top is the resonating part, and if you add weight to it at a particular point you will change its resonant frequency. Obviously you'll need quite a bit of weight, a few grams won't do it. But something like half a dozen litre cartons of juice/long life milk should do it.
Stack them up in the middle of one half of the bench, then plane something. Does the resonance change? If so move the weight around until you find the spot where it produces the most beneficial effect. Add/subtract weight to see what that does. If this solves (or nearly solves) the problem then you can screw the equivalent weight to the underside of the top. Or add some bracing underneath (maybe two diagonal braces, 2 x 1" on edge), though you're back into experimenting here to find the sweet spots.
That said, this seems the most unlikely answer. If the bench feels rubbery and not solid, then it's probably moving somewhere.
Osvaldd":25twk8r6 said:
Bod
"unfortunately the top is glued to the front apron, and the apron is glued to the legs. I will loosen the screws though."
There it is..
I'll bet the top is not sitting firmly on the bearers at the top of the legs.
Try screwing up through the bearers into the top, with a heavy weight on the top to prevent any "jacking" apart then the screws start to bite into the top.
The top is glued to the apron, but not quite at right angles, now the apron is glued to the legs, the back of the top is slightly raised. Hence the bounce, had the apron/top joint been the other way up, then the top would be pressing down.
Bod
Bod, I have pre-drilled proper holes in the bearers, there should not be a problem there.
I have glued the aprons first then put some glue on the edge of the top and clamped it to the apron at the same time while the glue was still setting I have screwed it from the bottom.
One thing I just remembered when adding aprons to the frame there was a slight miscalculation where the slots in the aprons were too close to each other by a few mm so I used a ratchet strap to pull the top of the frame and then slide the aprons in, bad idea probably. So there might be some weird tension going on between aprons and the frame.. or maybe this has introduced a twist in the frame and its doing something weird now.… well I dunno…
I have found that the most effective stiffening are diagonals from the centre of the apron to the bottom of the legs. I have two full length braces on the back of my bench and to maintain acess at the front the diagonals come from under the apron (not the centre) to about half way down the front legs.
Got me beat.
Let us know what you find...It's got to be interesting.
Bod
I notice that neither of your vices is aligned with a leg. The only place you ought to be sure of hitting the bench without a problem is directly above the top of a leg. If the vices were aligned with a leg you might be better set.
As others have said, the only way to reduce vibration is to add mass and/or stiffness (e.g. by diagonal/cross-bracing in more than one dimension) and/or damping (e.g. cork/rubber/etc pads under feet).
Are you sure it's not just a matter of getting used to your new bench - it's still early days I guess?
It looks nice anyway! Cheers, W2S
looking at the bench the aprons are not as big as a traditional bench, you might have a case of the bench top being much heavier than the sides, does the bench actually move when you're planing in the vice? if so it's not heavy enough, one of the things I did was added a very heavy 30-40KG unused metal vice on the platform underneath, it made a big difference, also try some wedges, I need them under my legs to stop it moving on an uneven concrete floor.
First, thanks for all your help.
I have tried many different things as suggested: added weight, loosened the top, removed the tool well, clamped a bunch of wood to different parts of the bench and found that, as you can see in the picture, a piece of wood between left side front and back legs and a piece of plywood across the bottom half of the back side have reduced ringing by about 80%. I’m happy now.
