WOODRAT or Router Table Any Views
Michel
11 Nov 2003
I've been reading about the woodrat and just wondered if anybody had one, or had any views on them. Or should i just buy a good quality CMT or Jessem router table?
Thank you
Michel
Alf
22 Oct 2003
Up the proverbial creek
Michel,
Now this makes a change. Usually 'Ratters have to sing the praises of the Rodent against jigs, rather than tables. I have a Woodrat, and I haven't used the router table more than twice since I've had it ('Bout 4? 5? years). However, it really does depend on the individual whether you like the 'Rat or not, so I wouldn't say categorically "Get one" to anybody. The main advantage it has over a table is that the router is the right way up. Therefore you're not fiddling in the dark to try and adjust the depth, sawdust isn't being helped by gravity into the motor and you can just see what you're doing. I was also drawn to it because the Woodrat stays out of the way on the wall, ready to go, while router tables take up space and always get used as convenient bench space. And of course there isn't a router table I know of that'll get you cutting dovetails, finger joints, tenons, raised panels etc without needing further jigs or expensive cutters. When all's said and done, you can build a router table with a 'Rat, but not a 'Rat with a router table :)
Some more idea of what sort of stuff you do would probably help us to help you btw.
Cheers, Alf
Michel
11 Nov 2003
Alf,
I must admit I've only ever used my router freehand. I would like to start routing dovetail joints and tenons for some small projects so was unsure which approach to take (woodrat or router table and dovetail jig).
How easy is it to produce accurate dovetail joints and tenons using the woodrat?
Does it take lots of experience to work out the setting out or is it fairly straight forward to set up.
Can you use the woodrat to do freehand work, for example rounding over a round table.
Any info would be appreciated
Cheers :lol:
Michel
Alf
22 Oct 2003
Okay, let's see (and bear in mind this is only my opinion)
Personally I think the 'Rat beats the rest for dovetailing. Not that it's the easiest, 'cos it isn't. But in my opinion it's the closest you can get to hand cut dovetails with a router, and you can use any make of cutter you like rather than being stuck with whichever one fits your jig. If you want to have an easy life though, you're probably better off with more of a "point and shoot" jig, although the 'Rat's little brother gives something like that option if you wanted. Personally I wouldn't want to give up the flexibility, but horses for courses. I like cutting tenons on the 'Rat, but I know others find it difficult. It certainly gives a better result than anything else I've tried, including a shoulder plane, so it's worth getting the knack of it. One reviewer actually reckoned it'd be worth getting just for the tenoning ability.
Getting to understand the Woodrat is not easy, and taking one of Mike Humphries' courses is often recommended. If you have the right sort of mind for it, it's less of a learning curve; I don't, so I've struggled a bit at times. However despite this, and even thinking of selling it at one time, when it comes to it I'd miss its capabilities too much to lose it. As an example, I've made a couple of shaker pieces that needed sliding dovetails to join three legs to a central turned post. I'm sure you know the sort of thing. On the 'Rat I was able not only to cut the tenon half of the joint on the curved legs without needing to make any kind of jig or special holding method, but with a simple workshop-made "sugar tong vice", as suggested in the manual, I was able to rout the mortise half in the turned leg too. Without the 'Rat I'd have to have made a bulky box to use with the lathe, while somehow getting the headstock to stay still etc, and then find somewhere to store it 'til the next time. Incidentally, the 'Rat is excellent at sliding dovetails and turns them into the easy option, so I use them a lot now.
To be honest I haven't done a lot of freehand work with it, but it's certainly capable of profiling the edges of round table tops. You might want to get hold of the CD-Rom which shows an example IIRC. One of the things I like is that you can use the north/south and east/west movement the Woodrat provides to rout housings, grooves and recesses all without having to clamp straight edges in just the right spot and all that palaver.
I hope that helps a bit. Like I said, it's not a simple case of "buy it". Only you can really know if it'll be the right thing for you. It might help to have a look at the manual and various downloads available on Woodrat's site. That'll soon give you an idea of whether you think you could get your head round it or not (kill or cure possibly!) If you can then for my money the 'Rat beats the table/jig combo every time. Which explains why I bought one. :lol:
Cheers, Alf
The Wizard
2 Nov 2002
Chesterfield, England
I have just ordered a Woodrat after looking at loads of different jigs and add ons for my router table. As Alf said "Getting to understand the Woodrat is not easy" :? , but after a demo from Mike at Stoneleigh I was convinced I could master it. I will post some feedback on this thread to let you know how it goes.
Wiz
Michel
11 Nov 2003
Hello all,
Thanks for all the info, I have ordered my Woodrat with all the 'bells and whistles',.
So can't wait for it to arrive so i can start practicing :lol:
Will keep you posted with my progress, hopefully i won't need to go on a course because I live in Guernsey so it costs a bit just to get over to you plus accommodation etc.
Thanks again :D
Michel
