I finally got round to making a storage unit for all the wee WoodRat bits and bobs...just so that I don't have to walk halfway across the workshop.
and a close-up of the unit is here
The unit was made almost 100% on the 'Rat..using the brush mounting technique for the vertical housing cuts.
While making this unit, I got rather frustrated with the inability to easily make housings (dados?) in the verticals at consistent spacings. I did start marking up the 'rat with pencil marks but soon realised that too many pencil marks makes much confusion.
So, I made up this EW calibration jig using Incra TTrack and Shop Stop. This gives me repeatabilty as I slide the workpiece underneath the router plate. I can either make a note of the exact setting...down to Incra's legendary accuracy
...or I can use the vertical stop that comes with the Shop Stop (not shown)
....or I can easily slide in the MDF extension piece that can slide underneath the router plate for use with smaller workpieces.
The Shop Stop is easily dismountable and transferred over to the right hand piece of Incra track.
The MDF extension piece slides in to a T-track on the Shop Stop. The length is sufficient to reach the centre line and so, in conjunction with the scale on the Incra track, I reckon that I can use this to make measurement that little bit easier.
The T tracks are mounted with M5 screws into holes tapped into the top of the 'Rat.
The next challenge is to calibrate the sliding bar using a digital display unit.
Aldel - you are very welcome to take the images for your site. I can take additional ones for clarity if needed.
