Wood for Countertop / Bar
Qscout
New member
16 Jan 2020
Ballyclare
Hi Everyone,
I have been reading through the forums trying to find an answer to my question but as a real amateur when it comes to woodworking, I am getting rather confused.
I am building a bar in our summerhouse and am looking for the best wood to make the bar top and counter surfaces. The bar top will be L shaped and I was hoping for a single piece so that I don't need to deal with joins. Dimensions are 1.7m x 0.7m at widest point.
I have some hardwood plywood (B&Q) don't laugh, in my garage that would keep costs down, but I don't know if this would be able to be stained and varnished to look good.
What would you all recommend that I use? Local Timber merchant said they can glue planks together to get the size, would this be a better option than the ply?
I don't really know what to ask for when going to timber yard, so simple terms if possible.
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
Qscout":34a34xxm said:
Hi Everyone,
Hi - I think you could do very well with ply. I would put a hardwood edge strip along all visible edges - here's an example of the kind of idea: https://www.youtube.com/watch?v=m7R6x67CyS0. You could perhaps use oak or a tropical hardwood like sapele for the edge trim strips. Anothor option instead of ply might be kitchen worktop - you can buy oak/beech/etc pieces online https://www.diy.com/ranges/kitchen-rang ... d-worktops
For either option you can easily stain and seal the results - I'd use polyeurethane to seal but others are bound to prefer different!
Cheers, W2S
thetyreman
4 Mar 2016
North West
have you checked that B&Q ply for flatness??? not trying to offend but it's not the best quality so I'd be concerned about long term stability.
PeteBowen
15 Jul 2016
Isle of Wight
I recently did something similar by cannibalising £40 dining table from a charity shop. There is a warehouse size charity shop near me filled with furniture just waiting to be turned back into planks. The dining table had a 40mm thick top made from glued together strips of beech (i think).
Cut to size, some sanding a bit of Osmo countertop oil and Robert's your male relative.
