Wood blemishes.
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
I have noticed that not only are prices rising but quality is heading in the opposite direction.
I bought some 119 by 12 t& g the other day, the number of imperfections seems to be up 110% just like the price.
Anyone know a handy way to camouflage them.
They're sometimes not deep enough to fill.
They're mostly one to two inches long.
Is it being painted? If so, you could carefully increase the imperfections depth with a chisel and then fill. Probably best to wipe the knots / resin lines with meths before filler. If you want to go full hog, hit it ( not literally ) with a hot air gun to make the resin come out, then chisel off when cooled, then meths...
And use knotting to stop bleed out into the paint in the future.
For a problem like this, I used to cut the imperfection out with a chisel, A 'V' shaped depth, tapered ate each end, then cut a a similar bit of wood so it roughly fills the cut-out and projects slightly above the surface A bit of glue and clamp the piece really tight using a flat surface to force the wood into the 'V' cut. Leave overnight, then unclamp and let it stand for a few hours to let the wood recover from compression, then sand it. I found if I could match the wood and grain, I could do an almost invisible repair.
EDIT. If there is resin in the flaw, I would remove as much as possible when cutting out the flaw.
