rafezetter
Troll Hunter
Hi all
There's been threads about drying wood and such but my question is one of what happens after it's been stored and dried but you want to work on it.
I've had wood stored in my bedroom for quite some time now, more than a year, and my el-cheapo meter says between 5-9% (I'll err on the side of 9%) but I do all my woodworking outside, and once started it might have to stay out there a day or two.
The issue is mainly jointing up planks for boards and how the wood might behave, the wood is old T&G pine (no idea which) planks that had been used to board up a room in the 70's (like they did) 13mm thick.
How much time will I have to work it before it might become an issue?
I also have some very old, what might have been roof sheathing, boards 12" wide by 1" thick (can't tell the wood as they are so grimy) that I want to use for a dining table top.
Will I be restricted to mostly warmer weather outdoor work, or if I work it then move back indoors in the evening, will I be ok?
thanks in advance
Austin
thanks in advance
Austin
