wipe on varnish
rob
New member
4 Nov 2005
nott's
Hi has any one tried wipe on polyurethane varnish and is it any good?
does it leave lines .If it is good which product did you use. :?
Cheers Rob
Ed451
15 Jun 2005
Eastern Canada
I've tried Minwax in both gloss and satin. It works good, but no better than the homebrew stuff I mixed up by thinning regular polyurethane with turpentine (or other thinner of your choice). It's a LOT more expensive than home-made, though.
Ed :)
Alf
22 Oct 2003
Up the proverbial creek
Rob,
I don't suppose you get Popular Woodworking from the US, do you? Pretty good run down about wipe on poly in the November issue. The gist seemed to be you can quite easily make your own, and it's worth doing 'cos it's the bee's knees. Thin any varnish which has white spirit given as the clean-up solvent 50/50 with white spirit and thin further if desired, seems to be the essence of the thing. I've never tried it myself, but I was tempted to give it a go, I must say.
Cheers, Alf
rob
New member
4 Nov 2005
nott's
Thanks both sounds like a good idea i suppose doing it that way means
more cotes ?.
Ed what cloth did you use.
Cheers Rob
Ed451
15 Jun 2005
Eastern Canada
Cloth? Well, to be honest, I just used a piece of an old T-shirt that the missus got mad and ripped up after she saw me wearing it. (it had some holes in it, but I was just wearing it as a work-shirt) Anyway, any good piece of cotton is fine.
Ed :D
newt
31 Dec 2005
Salisbury
I am currently finishing a project using home brew wipe on poly. First coat thinned 50/50 rubbed down when dry with 800 wet/dry. following 2 coats 30 white spirit 70 poly all applied with painting pads no lines or marks very smooth. I intend to rub down final coat and finish with a danish oil then wax.
LyNx
27 Jul 2005
swindon
can u apply danish oil over poly?? I think this may have had to be the first coat
Andy
Sgian Dubh
12 Oct 2004
UK
You can Andy, but there's little or no point doing so. Danish oil is essentially a form of soft varnish anyway. Covering a hard varnish with a softer one makes little sense.
If you were thinking of applying things the other way round there are some applications. Slainte.
