why does a dead button battery still put out full voltage?
TheUnicorn
21 Feb 2020
South West
Went to turn on my kitchen scales yesterday, nothing on the screen whatsoever. Put a replacement battery (a 2032, which was like for like) in, from a packet that had been sat around far too long, again nothing. A ran a multimeter over both batteries and they were both putting out a solid 3 volts. Went to the shop today, new battery, scales works no problem.
I think I'm right in saying that in alkaline batteries rated at 1.5v (AAAs and the like) a battery is normally considered dead when it reaches 1.2v (roughly, obvously some variation according to the device they are in), so by that logic 2 x AAA would put out 3v new (possibly slightly higher in reality?) and would stop being useful at around 2.4v.
So why is a lithium button battery that is still putting out full voltage not powering my scales.
I assume that they put out a consistent voltage but the amps drop? Is this they reason that button batteries have become so common place?
With primary lithium cells the discharge generally manifests itself as increased internal resistance. It isn't a question as to whether it can supply volts or amps as they are fundamentally interconnected in any given circuit. Rather as the current drawn from the battery increases the voltage it supplies decreases.
A modern DMM as a voltmeter has essentially infinite resistance for common and garden purposes, from an electrical perspective it is effectively not there at all, so you read the full voltage. In the device current is being drawn which reduces the voltage. The same voltage is still being generated as it is governed by chemistry, but it's being lost inside the cell.
? so under load the battery is not putting out 3v but as the multimeter is not putting the battery under load reads it at 3v ? have I understood that right
@ajs is exactly right. If you really want to measure the condition of a battery it should be measured under load, preferably a similar one to the product it is used in. this will expose any deterioration due to internal effects like an increase in the internal resistance.
EDIT: our posts crossed. Yes you have understood it correctly.
so as I couldn't get a probe to the underside of the battery, in situ in the scales, in practical terms there is no way of testing the battery, just replace it and see if the device works?
It was a bit annoying last night not knowing if the machine or the battery was dead.
could I remove the battery holder from some 3 volt fairy lights and try to power them with a button battery? trying to think of a solution that would test any size (dimensionally, not voltage) of battery
My inexpensive multimeter has a '9v battery' and '1.5v battery' test position. I believe they put an appropriate resistance in series with the battery to determine whether or not it can deliver the power it is designed to.
Am I thinking along the right lines, please?
You could possibly slip a bit of tin foil under the blind side with a bit of tape to insulate from the live battery rim.
Cheers, Andy
A new 2032 should measure closer to 3v6 when open circuit, IIRC, so 3v0 is not so good.
'open circuit' meaning not under load? so I can still use the meter to test, just need to look for the actual (full) voltage as oppossed to the nominal voltage of 3v?
Just re visit ohms law, this is why you can get electrocuted by touching an open circuit neutral and an issue when dealing with PME electrical supplies..
Possibly /probably. Try reading the voltages with the battery tester setting and with just DC volts. If the battery tester reads slightly lower then odds on it has a loading resistor built in. The resistor is in parallel with the battery to put a dummy load on it.
Put a small light bulb across the battery. This will put a load on the battery and give a true value or the batteries potential.
OK for a battery like an AA but probably too much load for a button cell. Sorry can't think of an easily found and applied suitable lighter load unless you have a selection of resistors to hand.
If your scales stop working, try changing the coin cell. If that fixes the problem throw the old coin cell out(preferably take it to the supermarket and recycle it).
Alternatively, measure the open circuit voltage of a brand new 2032, and use that as a rough yardstick.
Third option - build yourself a test rig with a selection of different resistor values that you can switch in and probe points for your meter. Make a graph of your findings.
The voltage would drop off very quickly if current drawn. This is why you need a very big 12v battery in your car, and why the current from 12v torch batteries would not replace it.
I'm unable to offer an answer to the OPs question but would put forward acquiring a little 'battery tester' - as in my photo - to use rather than a multimeter? I've used it here - in the photo - to check a batch of newly purchased LR44 button batteries, purchased just before Christmas, for one of my grandson's presents. All of the ones tested came up with the same readings.
    1.1 MB
    1.5 MB
My dad had an old Ford E93A back in the 60s. A "Sit up and beg" Popular.
Like most of his motors it was pretty well gone, and so was the battery. A 6V system. Anyway he used to hand crank it, but even then there wasn't enough juice from the battery for the ignition coil. So he wired two six volts lantern batteries up to a changeover switch. Used to fire the old girl up, the amount of oil it burned meant plenty of smoke, and then once running he'd change over to the main battery.
Rover P5B 3.5 coupes(and doubtless many other cars before electronic ignition) had a ballast resistor that was in series with the coil, but was bypassed by a secondary set of contacts on the starter solenoid. If those contacts failed, the car was almost impossible to start.
That sort of arrangement was fairly common back then. I've never actually measured the voltage, but cranking an engine, particularly a freezing cold one, when the battery isn't at it's best either pulls the voltage right down without the ballast.
My 1966 Vauxhall Victor had that. A friend serviced the car for me and managed to bypass the resistor, meaning that the 6V coil was running on 12V. It started and ran beautifully until it didn't (at night, obviously). Huge carbonised track down the rotor arm in the distributor. I changed the rotor and started the engine, and the whole HT system flashed and sparkled like firework night!
Les
