Which turpentine for beeswax finish
I was into collecting antique furniture when I was a teenager. Some lovely stuff could be got for a few shillings then (1960s) I used to make a polish with beeswax and turps substitute and it was fine. I still have some of the furniture I polished with it. Now I have a bit more cash I use beeswax BLO and pure turpentine. It smells better but I’m not sure there is any real difference in application or effect.
I've used white spirit/turps substitute successfully for softening wax polish it works well as does genuine turpentine, but its much cheaper. Here are a few observations over the years and also I'm a working chemist so can comment on chemistry and safety. I dont think you need the expense of genuine turpentine, unless you like the smell.
1. Most important is don't heat the turps or solvents as they are highly flammable. Instead melt the wax first over a bain marrie or glue kettle as @Phil Pascoe recommended pour into a jar (old jam jar) then add the solvent or solvents, and then stir in the solvents with no heat applied. Be very careful with warm solvent as it can explode if near a source of ignition. Also see the exposure limits for the solvents in point 5.
2. Beeswax and canuba wax are food safe. Canuba wax comes from the Brazilian palm tree.
3. White spirit can be quite variable in the oils contained in the solvent so select a well tried source. Good White spirit should be odourless. In the UK there is a BS standard BS 245 or German DIN 51632 these ensure they are suitable as solvents for washing brushes etc and also get consistent results for plasticising wax. This standard means the toxic (sweetish smelling) aromatic oil has been removed and also the more volatile kerosene smelling oil fractions has been removed. So quality white spirit whilst cheap (it comes from an oil refinery by the tonne), should be odourless. If it smells sweetish or kerosene I would be careful not to breath and only use for cleaning brushes. White spirit is not ideal for thinning paint as its not that volatile, but is great for softening wax.
4. Turpentine has a strong distinct 'pine' smell, this comes from its chemical structure it has a double bond (also called unsaturated hydrocarbon) and its shape mean that the nose can distinguish its distinct smell. Some people like this smell in furniture - antique effect. However its can overwhelm food so if in contact with food or children's toys, its better to use odourless turps substitute.
5. Toxicity, Turpentine is more toxic than white spirit (to the BS or DIN standard) the exposure limit in the USA for Turps is 100ppm for an 8 hour day and 500ppm for white spirit (called turps substitute). EU will be similar if not more stringent.
6. For first coating, I've read that some people add boiled linseed oil to the mixture in the ratio 1/3 turps(subs) 1/3 boiled linseed oil, 1/3 wax. The boiled linseed oil give it a darker appearance and brings out the grain better. I've not tried this myself. you could just give the surface an oiling before waxing.
White spirit BS245 and turps substitute may or may not be the same thing - there is no B.S. for turps sub.
Whilst you can buy low odour white spirit, I've yet to come across one that didn't stink.
Low Odour White Spirit 2L | Toolstation
I read an article by Ronald Rustin many years ago - he said always to thin oil based paints with W.S. never with turps sub. as there was no guarantee what was in it. Manufactures can use anything they choose, there's no standard. White spirit is not ideal for thinning paint? I wonder why paint manufacturers recommend it - what else would be used?
Good points. Sorry I've probably been a bit loose as my bottle has White spirit and turps sub written on it. Bs245 and Din 51632 are the best ones to go for. They will all smell of oil, but cheap Turps substitute may well smell of aromatics (a sweetish smell, toluene, xylene but more worryingly benzene the later is very toxic and is in cheap petrol and cheap turps substitute etc) the lighter fractions are much smellier, so low odour rather than zeor odout. Not sure what they call this in Slovakia.
They recommend it as its the safest thinners. Its one reason oil based paint takes ages to dry. Although in warmer countries its probably fine.
Professional decorators in the UK usually add another solvent to their thinners, usually one with a naphtha or lacquer fraction in it with more volatile additives. Sometime they add drying agents (catalysts) that speed up the chemicals bonding of the coating paint, especially in cold weather, but they also speed up the ageing of the coating as it gets more brittle over time than without the catalyst.
Thank you very much. Do you recommend some respirator working with turpentine? Is N95/FFP2/FFP3 enough or I should have something better?
No you will be fine doing this in a ventilated shed. Just don't slosh solvent around willy-nilly. If you spill it, wipe it up and then leave the room for a bit.
Masks of that sort eg N95 will be of no use as the solvent will diffuse through them in the air, the molecules are tiny they are about 10^-9m in diameter whereas N95 is designed to filter-out particles (eg covid19 droplets) that are 10^-6m in diameter about 1000 times bigger.
However for a small job like a jam jar full and a piece of furniture such as your workbench you should be below the exposure limit if you do the work in a well ventilated room. Open the window of your shed/garage and you should be fine.
The key thing is not to over expose yourself. The long term effect of these solvents is damage to your nervous system (ie increase the likelihood of nervous deceases such as Parkinson's, MS etc) . The occasional finishing of jobs will be fine.
Professionals who wax furniture all day for a living should take extra precautions such as having a ventilated cubicle for this kind of work for use a forced air face mask. For your job don't worry. The key point is don't slosh the solvent around willy= nilly (sorry English term - don't splash it everywhere as if it was water).
Oh and the final point is white spirit is 5 times less hazadous so you can wax five times more for the same hazard to your heath, so be a bit more careful with Turpentine.
I did query some white spirit I bought from B&M (iirc) as there was no standard number on it. The reply said that it had to comply with B.S. 245 to be sold as white spirit .......... which made me wonder it didn't carry the B.S. No. if that was the case.
Um, not sure I'd trust B&M to know. B&Q yes, but a bargain basement company, you wonder what audits they do on suppliers?? I imagine some years its good stuff ie left overs from a reputable supplier (even reputable ones in China) and some years its, um, lll Russian or Chinese anything goes.
Wow you learn something every day. I recall seeing the term gum turpentine but it register in my brain. I would like to get some gum turp to see how it works.
we are having issues now with solvents. Environmental issues with voc release. I never thought turp would be on this list. I actually like the smell of turp and wax.
The inquiry was in writing to their head office not the store, so I assume someone checked it out.
Thanks TominDales,
Is it possible to "cook" the mixture outside? My workshop is all made of wood with a lot of wood, wood dust,shavings,.etc inside. In case I set the mixture aflame (I will use bain marie, but I am doing this for the first time, so I want to be cautious)
Thanks TominDales,
Yes . I often do so as it's much safer. We have a shaded patio area and on a suitable day I varnish and paint out doors. Not always possible in the UK!
If you melt the wax in the Bain Marie , turn off the heat, and then stir in the turps you will be fine.
I salute your safety consousness. It annoys me that so many solvents and chemicals are banned, just because DIY folk won't heed precautions and work sensibly. We can't get DCM (nitromoors) in the UK without taking an exam and getting a certificate that costs £300. And because our government is fed up with fools that ignore all precautions and then sue the government for compensation when they get sick.
Good luck
Good luck
Well,
I am the kind of person who attracts accidents and injuries easily. That is one reason why I work mostly with hand tools. I only use thickness planer and also I use circular saw (skilsaw) only when I buy big slabs of lumber and I need to crosscut and rip them to smaller sections. I even rip wood to project dimensions by a hand saw. I do my best to work according to the safety precautions, but nevertheless, with power equipment it takes a split second to cut one's finger off and make irreversible damage to one's health.
I am maybe the only person who wears safety glasses when chopping mortices with a chisel (I have never seen anyone on youtube wear safety glasses when chopping mortices). I have chopped just a handful of mortices, but already I was glad that I had the glasses, because small pieces of wood just hit the glasses when chopping (If I did not have them, I would need to go to eye emergency to remove those particles from my eyes.
I
I've just been onto their web site and the white spirit sold seems to all have BS 245, and the turps substitute specifically says not as well refined at WS so not suitable as paint thinners. I think your enquiry has sharpened the practice. Its looks a decent store I'll look for one locally. I tend to support our local builders merchant, nice guys live locally etc. Life must have got harder since Screwfix and Toolstation opened in the out of town, but they are still service the local trades people. One thing I like about living up here in Yorkshire is the town still supports local trades.
It's quite good for DIY decorating stuff, and just like Lidl, Aldi , Farmfoods etc. it's very good for some things, not everything. We're lucky - we have a Bradfords, a TP, a Wickes, a Screwfix, a Toolstation and five good independents within 6 or 7 miles.
Well,
Very sensible. Always wear safety classes, I've seen their benefit on several occasions.
One thing that struck me, you mentioned saw dust etc. Probably worth carefully sweeping and vacuuming it up every few days as dust is not only toxic but flammable. In fact fine dust can explode if in high enough concentration - there is a party trick with custard powered on this.
Without taking proper precautions we all attract accidents. I've met a fair share of know-alls who dismiss PPE etc until they have an accident, to be fair a few are quite humble about it, but some recon it was not their fault and don't learn. And a few who were unlucky enough to work for rogue employers. My first jobs/holiday work was on a farm and one guy had lost 3 fingers to separate incidents with the same harvester. I then joined the chemical industry where HSE is deeply ingrained.
I'm scarred to death by my too-cheap table saw and prefer to use hand tools wherever possible. Its my hobby so I'm not up against customer deadlines though.
Safety specs save the day. A guy in my lab had his flask blow up and a large curved glass shard imbedded in his forehead. Safety specs completely black, pitted, cracked and bloody, but his eyes fine. The prof nailed these glasses to the lab notice board as a grisly warning to all students.
A friend had a freak accident, a saw blade broke off and came through the wall of his TS, it flew away from him, hit a tin of paint that exploded (must have been v hot) and the fireball hit him full in the face. Singed hair and face burns, but safety glasses saved his eyes.
A chap I used to drink used to get fed up with people taking the pee because his new job was as a H&S officer on building sites. He came in one night with a fair sized book of photos of dreadful injuries - as he pointed out, every single one was preventable. A problem is that over enthusiastic enforcement does no favours - another chap there ran a professional decoratoring firm, his men had just been pulled for not wearing hard hats. They were painting skirting boards in a school.
I'm with your on this. The past chair of the HSE was Dame Julia Hackett (ex ICI). She railed against enforcement of daft rules, nearly always by people who couldn't be bothered to do things properly so banned them. At one point our city banned pancake races citing HSE and Dame Julia verbally tore a strip of them.
In my experience there is a learning curve. HSE comes into work, its initially very rules based, bureaucratic with lots of forms inspections, fear and ignorance, gets a mixed reaction from people who are supportive but frustrated and take the Pee.
However the workplace starts to learn and understand more deeply, risk assessments get done, Safe procedures get written by experts who know their tools etc and a more nuanced approach is adopted. People get encouraged to participate and employs get supported when reporting learning experiences and safety improvements and low and behold accident rates fall.
All accidents can be prevented is a very good rule of thumb. There is nearly always a route cause to an accident.
What has surprised me most in my career over the past 20 years or so, how the building trade has adopted HSE. From laggards with terrible LTA rates to really very good practice.
I was a cellarman. I got pulled one day for bouncing kegs off a loading bay onto a dolly bag and into the cellar, as for some reason the inspector found it to be dangerous. I told my boss to write back and say they they'd better ban every brewers's dray in the Country until a better method was found. We heard no more.
I worked on a major bridge build in '73/'74 and H&S regs were in their infancy. We had safety harnesses turn up as individual parts - rope, harnesses, carabiners etc. all seperate. It was a bitterly cold time so I sat in the welder's hut and made them up. The H&S man came round and asked who'd done them. Me, I said, and they're perfect. Just look at them - splices tapered, sailmaker's whippings. Have you a ticket to say you're qualified? No. Well we can't use them. OK, I said, use them until another lot turn up (strikes every blink of the eye - what should have taken days took months). No, he said, I can't allow it. For another three months we worked with no harnesses.
