Quantcast
"which" questions
kityuser
12 Jan 2003
charley, might it be worth having constant polls arranged, with the results available on a dedicated page????
readers/users could then view the answers to questions such as "which table saw/router/drill/ should I get....." quickly
prehaps have different cat.s for, light, medium and professional duty???
just an idea....
cheers
steve
Adam
10 Sep 2003
UK
I like that idea.
Very clever!
A
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Steve
I think the idea is great.
My only concern is how do you handle the models that change fairly frequently. Also, it would have to be at manufacturer/model level to cover the areas where a manufacturer might sell their own items up to a certain level and then re-badge items from someone else.
Neil
kityuser
12 Jan 2003
there are obviously issues to be considered........
I was just proposing the idea to charley.
if a model goes out of production, you could take the option out of the poll but still display the result data (ie how popular that model WAS)
at the end of the day, lets not get TOO picky, after all some data may be more use to everybody than no data!
> you could have several model covered under the same poll option (past models and present ones)
Charley
24 Aug 2002
Collingham
sounds good to me, how about we use this thread to start listing all the models to go into the polls. Shall we start with routers? Light, medium and heavy duty.
I'll start with
Porter Cable 7529 1/2" & 1/4" :: Heavy Duty
CYC
23 Jul 2003
Kildare, Ireland
Here is a list compiled from models available on Axminster and Rutlands site, sorry I don't what category they will fall into:
Axminster AW127R 1/4" & 1/2" Router
Axminster AW635R 1/4"-8mm (1/4") Router
Axminster Router Carry Case
Bosch GOF13000ACE MkII 1/4" - 1/2" Router
Bosch GOF2000CE 1/2" Router
Bosch GOF900ACE MkII 1/4" Router
CMT 1850 1/4" & 1/2" Router
Festool 2000E/1-Plus 1/2"
Festool OF1010EBQ 1/4" & 8mm Router
Hitachi M12V 1/4" & 1/2" Router
Makita 3612C 1/4" & 1/2" Router
Makita RP1110C 1/4" & 8mm Router
Metabo OFE1229 Router
Trend T3 Routing Kit
Trend T3EK, 1/4" & 8mm Router
Trend T5E 1/4" 8mm
Metabo OFE738 710W COMPACT PRECISION ROUTER
Porter Cable 7529/OFT 2 PEAK HP ½"
TRITON TRB001 2200W ROUTER 230V
Metabo OFE1812 1800W ELECTRONIC 1/2" ROUTER
Trend T9EK 1/2" ROUTER 1800W C/W CASE & HEIGHT ADJ
Trend T9ELK 1/2" ROUTER 1800W - 110V WITH CARRY CASE
Porter Cable 7529/OFT110V 2 PEAK HP ½" 110V
Porter Cable 9290 19.2V CORDLESS ROUTER
Porter Cable 7539/OFT 3 1/4 PEAK HP 1/2" PORTER CABLE/FLEX ROUTER
Porter Cable 7539/OFT110V 3 1/4 PEAK HP 1/2" PORTER CABLE/FLEX ROUTER
The names may need to be refined but it's a start :wink:
kityuser
12 Jan 2003
sounds good to me!!!!! (my first good idea *fanfare*)
router : FREUD FT2000E PRO DUTY
PPP (B&Q) 1250W MEDIUM DUTY
Chop saw : DRAPER 1800W (12") MEDIUM DUTY
Jig saw : Bosch PST 850PE LIGHT DUTY (green not blue)
Newbie_Neil
27 Jul 2003
Nottingham, England
Here's a few more
DW625EK 1850 Watt 1/2" Variable Speed Plunge Router
DW626 DEWALT DW626 2300WATT 1/2INCH VARIABLE SPEED PLUNGE ROUTER
FREUD FT2000E 240VOLT, 1900W 1/2IN ROUTER
MAKITA 3612C 1/2"
METABO OFE1812 240VOLT, 1/2in 1800W
DEWALT DW613 230V PLUNGE ROUTER 6-8MM 800W 1/4"
DEWALT DW615 240VOLT 1/4" 900 Watt
DEWALT DW621K 240VOLT
MAKITA 3620 1/4in 860W 240VOLT
MAKITA RP1110C 240VOLT 1/4"
METABO OFE1229 240VOLT Output power 780 watts 1/4"
Neil
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Routers:
Trend T3EK - Light Duty
Bosch 900 ACE - Medium Duty
Freud FT 2000E - Heavy Duty
Rgds
Noel
Adam
10 Sep 2003
UK
Mafell LO50E
Mafell LO65E
Festool OF1000e
In the same survey, should we be asking if people ALSO have a router table AND/OR a woodrat as well - after all they seem to tie in together.
Adam
kityuser
12 Jan 2003
sounds good to me ...
charley , how was you planning on keeping the results of this thread???
Charley
24 Aug 2002
Collingham
Tomorrow I'll create a new section on the forums where I can create polls for the different tools where people can vote (and not post) for which model they recommend. Is that what you had in mind?
Gill
3 Sep 2003
Lincs
Hi folks
Do we have a lot of people here who work in marketing? This sort of info will be invaluable to the men in pin-stripe suits.
Yours
Gill
kityuser
12 Jan 2003
sounds good to me charley, prehaps other info could be extracted/displayed like OVERALL perfered manufacturer.........
Adam
10 Sep 2003
UK
Charley,
Are you going to add the other Routers (medium/small?)
Adam
Neil
7 Oct 2003
Ireland
I think thats a good idea too, Adam. Charley, could we keep them as a separate poll to differentiate them from the existing list which I guess would be used mostly in a table? I think many people would have (or would like!) one of each size. Maybe we could have something like 'Professional 1/4" routers' with things like:
Trend T5
Bosch GOF900
Makita RP1110C
Metabo OFE1229
Festool OF1010
(yes this list was lifted straight from Axminster :oops: )
I think it would be best to keep the DIY-type routers off this list as there are so many makes/clones and it all gets a bit confusing.
NeilCFD
