Which motor?
Arnold9801
26 Sep 2016
Cornwall
Could anyone advise me please re which motor is best to convert a 3 phase pilar drill to single phase?
I got a beautiful Progress floor standing drill but it's no use to me as its 3 phase.
Regards
CHJ
31 Dec 2004
Cotswolds UK
Depending on how much Power you need for your drilling requirements it is possible to run your 3PH motor on single phase using a Run Rated capacitor to generate a simulated third phase.
Is your motor a dual voltage version that can be wired for 400/240 volt (Star/Delta) operation.
If so in Delta form:-
C = 70 x kW (formula for 230 50Hz 3-phase motors to run on a 230V 50Hz single phase supply)
For example a 0.37kW motor would require a 25µF cap.
Often enough power for hobby use.
Could get you up and working whilst you sort out phase convertor or new motor.
topchippytom
14 Jun 2019
ebbw vale
Regards
I have a 3 phase converter in my workshop no longer required as i updated to a 15 HP one due to bigger machines,It is a clark 5.5 HP and will run your drill quite easily
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
If the motor can be or is 220 delta you can use a VFD (Variable Frequency Drive) to convert 220V single phase to 220V three phase for about a hundred pounds or so. Bonus is having the variable speed for drilling.
Arnold9801
26 Sep 2016
Cornwall
I'm away from my workshop at the moment, so that's all I can say is that it's a "Hoover" make 3 phase motor.
TFrench
6 Jul 2015
Leics
Hoover industrial motors are very common on old stuff. Get a saved search on ebay and you'll get hold of a 240v one within a couple of weeks. The mechanical switches in old drills are very easy to wire for single phase as well. If you can't find a hoover motor the main things you are looking for are the motor power, shaft size (it will be imperial) and foot mounting hole pattern. You'll have to trawl through a lot of tat but you'll find one quite easily I'd have thought.
topchippytom
14 Jun 2019
ebbw vale
Seems a lot of hassle,I am a big believer that 3 phase was built for a reason (industrial) I changed all my kit from 240 v to 440 v 3 phase and the difference in the machines in just unreal ,Had an old wadkin planer 240 and would really struggle on big timber where the 3 phase one never even drops in speed when running 300mm wide boards through. Just my own opinion
