Random Orbital Bob
Advice would be appreciated please:
I'm upgrading my bandsaw to a tool with greater capacities that will perform better with larger logs for bowl blanks. Currently with the Record BS300 its just not man enough for larger logs as the depth of cut isn't high enough. (190mm) I'm looking at the mid range machines with a 16" type throat. The Axy ones and Record are coming in at around the £1100 ish mark. These generally have a depth of cut of around a foot which is a big improvement on my current model and also double the HP motors. Jet are very expensive for the same capacities. Is there any other well known and robust manufacturer that I'm not considering that perhaps I should?
Many thanks
Many thanks
