Which dust extractor charnwood, Axminster or itech
Luketheduke
2 Sep 2013
Gravesend
Hi guys I'm after some advice/opinions in these three extractors... Currently it's only for my 10 inch table saw and small thicknesses/planer. My options are as follows:
https://www.scosarg.com/itech-dc001s-1- ... uXEALw_wcB
Most powerful but looks the least well built
http://www.axminster.co.uk/axminster-tr ... tor-508334
From Axminster so good service, also good ISH reviews
Finally:
https://www.charnwood.net/products/prod ... athway-110
Looks really well built but no reviews
Thanks for your help in advance guys!
The Charnwood W691has a 5 micron filter. The W796CF W796 has a 1 micron filter. So, if you're sanding to fine levels, you may want to go to a finer filter.
The Axminster Trade AT60E has a 1 micron filter.
I'm interested in the Record Power range though, it filters down to 0.5 micron.
The RSDE/2 looks good: https://www.recordpower.co.uk/product/f ... IEnISj7TIU
Does anyone have any experience with these?
I would go for the FM300BC and if you need more fine filtration get the cartridge to replace the bag. That's what I did and it's a great extractor.
RickG - you're not comparing like with like in terms of the RP extractor, it's low volume high pressure whereas the others discussed are high volume low pressure.
The Charnwood extractor has a 16a plug, if that's significant for you, whereas Fox's similar 2hp variant runs off 13a. It's a decent price at around £250 ish and f you have concerns about the brand it has a 3yr guarantee.
The Charnwood 691 runs fine on 13amp plug.
Thank you.
I see the FM300BC also has a collection bag. This also means you can dump the waste without risk of inhaling spores when you empty it.
