Hi, I am after a top quality coping saw, any recommendations?
Cheers, Mark
Cheers, Mark
yetloh":1dz2w54n said:I wasn't aware of the woodworkers version, but I have this one http://www.palmermetals.co.uk/shop/...llers-saw-5-inch-with-swivel-blade-clamp.html It works extremely well for dovetails and is a lot less expensive than the titanium version. I'm not sure what advantage the woodworkers version would offer but perhaps Derek can enlighten us.
Jim
I've got one of the WH fret saws and have been disappointed by it No matter how hard you try to wind on some pressure to tension the blade, it always seems to be flabby, so I'd definitely be interested in one of the Woodworker's titanium saws...even if they are a bit spendyPeter Sefton":2tmy7fgx said:These fretsaws do look fantastic - far more sophisticated than the ones I use, I have three sizes 70mm, 100mm 150mm (the largest I use for marquetry work).
The small one is my oldest and favorite – I have had it over 20 years and it’s still going strong. I have bought some more recently for my student tool kits from Axminster at about £11.00 each. The handles came off and I had to Araldite them but I know that Workshop Heaven now sell something very similar. If you need to do dovetails in a wide board and your saw frame catches the timber, just use a pair of pliers to twist the blade by 45 degrees and then you can cut all the waste out across the board.
Cheers Peter
Racers":3f0hp4gb said:Hi, Gazpal
Can you do this with an Eclipse?
It was done by several people at a bash so its not operator skill.
Derek, thanks for the linkies. I've changed over to my old Groz fretsaw from Axminster and even though it's only a cheapie, the tension I can get on fret blade is far higher than the WH saw - RobHi Rob
It is termed, the "woodworker" version.
Try this link: http://www.knewconcepts.com/titanium.php
Woodworker:
5" Woodworker Aluminum with Cam-lever & Swivel Blade Clamps ($95.00)
Titanium:
5" Titanium with Cam-lever & Swivel Blade Clamps ($195.00)
Regards from Perth
Derek
