Where should I post my question?
Status
Not open for further replies.
Stemck
New member
5 Apr 2021
Uk
I have a wooden shed already built and was wanting to insulate it.
The batons to the shed walling give me 43mm. I have an opportunity to get some free kingspan insulation to do it, however it is 50mm thick.
Is it possible to use this and squash it down with the plywood boards I am going to put over them?
Angie
Administrator
Staff member
Admin
Moderator
10 Aug 2020
Please post this where the members can see and advise you. I'm sure others have done the same and can help you find the best and best cost for your project.
Stemck
New member
5 Apr 2021
Uk
Thank you,
I'm new and don't really get how it all works yet
eribaMotters
12 Feb 2010
Formby, Merseyside
You will not squash the Kingspan. Rip down some strips of softwood about 9 or 10 mm thick and pin these to the 43mm thick framework. Cut and jamb the Kingspan in place and then fix your ply. I thick the small gap will help you getting a good fit if you have cut the Kingspan a bit to tight.
Colin
Cabinetman
5 Jan 2017
lincolnshire Wolds
Hi, top left-hand corner you’ll find forums and you go in there and find the right one for the sort of question you’re asking. Now your shed no it will not compress, but the plywood will span the batons and just leave a gap and screw into the batten or if you’re really fussy use some seven mil thick strips. Ian
Ps welcome.
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Please reply in GW thread. Thread now locked.
Thanks for advice CM.
Status
