What's wrong with my laptop keyboard?
Benchwayze
10 Mar 2007
West Muddylands
First off I can't touch-type, and at this stage in life I don't think I could start to learn.
I have noticed that as I type, as I am looking at the keys, my cursor jumps all over the place, and I end up over-typing in a different part of the document, completely unaware that this has happened. It is pineappling me off. Does anyone know what's wrong and is there a cure?
I thought this was problem only with wireless keyboards. :evil: :evil: :evil:
John (hammer)
profchris
14 Jun 2015
Suffolk
I suspect the heel of your hand is brushing the trackpad. Put a cloth very it and try again.
In Settings you can adjust trackpad sensitivity (or quicker, get a child to adjust it for you).
Benchwayze
10 Mar 2007
West Muddylands
Really!!! As simple as that? Well uncle that try I'll be a monkey's!
Thanks Prof. I will try that!, as thinking about it you could be right! Gaffa Tape here I come.
Thanks again
John (hammer)
novocaine
21 Jul 2014
Warrington
Theres a setting in the track pad options to turn it off when typing (normally,on most laptops). Bet it was turned on before and some update or other has deactivated.
--Tom--
16 Oct 2016
Cardiff
My old one developed a dodgy connection that did this.
Being a work machine I replaced it as wasn’t worth the hassle to fix.
On most touch pads you can double tap top left to disable it, and I had to do that anytime I wasn’t using a separate keyboard/mouse
Benchwayze
10 Mar 2007
West Muddylands
Thanks Tom.
I do use a separate mouse; a wireless, but I am thinking of going for a USB or a good old serial mouse. Wireless Meeces :) seem to die within weeks of purchase! I can't do any more than just keep my wrists away from the mouse pad at the moment, but once I get home, I will cover up the mouse pad property.
In the control panel I could find no mention of the track-pad settings. Or of the mouse TBH. So I'll put up with this until I get home again and can use my PC proper. USB mouse will be a first purchase after my discharge!
John (hammer)
