Quantcast
What wood for children's play equipment
yeti
27 May 2017
Essex
Looking to build some monkey bars for the children in my back garden. Quite a simple structure from say 2" x 5" boards, with ~1" dowel for the bars. Something like this, but smaller and not in oak!
https://www.playequip.com/monkey-bars-for-adults/
Question is, what softwood should I be using which will give me say 10+ years use? Want minimum maintenance and any protective paint/oil should be child friendly..
Brooks Brothers are my (very) local wood merchant and they sell a variety of softwoods here:
https://www.brookstimber.com/softwoods.php
Western Red Cedar? Redwood with a protective oil?
I don't mind the wood colour fading with age; think it adds character to the piece.
ED65
3 Dec 2015
Softwood, for the dowels? Doug fir might be strong enough but I think you'd want to use hardwood at least.
J-G
20 Jan 2014
ATHERSTONE
I suggest that a ~1" dia bar is far too small - even for children!
I would start thinking at least 40 - 50mm - and certainly hardwood - beech, ash, elm....
It might be an idea to look at wooden curtain pole - unless you have a lathe that can handle the length needed.
Fitzroy
All the gear...
12 Mar 2013
Aberdeen
You’ll not want a bar with too great a diameter as the kids will not be able to grip. I’ve seen kids wooden monkey bars on friends climbing frames with a diameter of c. 25-30mm but they are only 300-400 mm wide, nothing like the span on your picture.
With regards materials lots of the commercial frames seem made of southern yellow pine that’s been pressure treated.
A kids play frame is in my to do list and I plan to make it from yellow treated building timber.
Fitz.
yeti
27 May 2017
Essex
Thanks for your comments. Regards the dowel width, I've some old curtain poles and my boy prefers 32mm in tests.. Thanks for the link to toolsandtimber; the bars in oak work out about £2 each, which is ok.
What about the frame material? I cannot afford hardwood so thought Western Red Cedar was a good alternative?
ED65
3 Dec 2015
To be on the safe side even going with oak you'll want to select your pieces with care. Grain runout can significantly weaken a dowel, just like it can a hammer or axe handle.
yeti
27 May 2017
Essex
Ok, thanks for the info on dowels; that one is squared away.
Any thoughts on the softwood frame material please?
yeti
27 May 2017
Essex
Any comments on the software for frame material please?
or what appropriate preservative if using Redwood?
AJB Temple
Finely figured
13 Oct 2015
Tunbridge Wells
If I was doing it on a tight budget I would use pressure treated tanalised softwood framing timber. You can get a 10% trade card from Wickes very easily. I would dip all ends in a bucket of timber preserver. I would probably construct with timber-fix screws or coach bolts.
If I want it to last 10 years then I would use oak frankly and be done with. Buy from a lumber yard.
