Quantcast
What tool(s) would you buy for £200?
BenB
9 Nov 2020
Kingston
I have a couple of hundred pounds to spend on a birthday present for myself, not a huge workshop. A full-sized lathe won't fit easily
What tool or tools have you bought yourself that you used all the time or gave you particular satisfaction?
I already have a drill/driver, impact driver, table saw (rescued from the tip), jigsaw, mitre saw, router & home-made router table, cheapo pillar drill, 3D printer, cheapo bandsaw, multi tool, pocket hole jig, I was looking at the mini circular saws (Worx etc) planers, sanders, lathes, and various gadgets
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
Track saw.
I never had one until 3-4 years ago.
It gets more use than I ever imagined it would.
After the mitre saw and the table saw .
Noggsy
28 Dec 2011
Runcorn
It obviously depends on what you’re doing. For me, I’ve got a Quangsheng no. 7 plane from Workshop Heaven that I use all the time. I’ve got a Veritas block plane I got secondhand and again, I use all the time. I’ve got a Record 4 1/2 that I got for about £25 (from here) and I’m finding I reach for that instead of the 5 or 5 1/2 now.
Off the bench, I’ve got a carving drawknife that stays razor-sharp just from stropping (Axminster) that I love. And a Japanese splitting axe from WSH that gets weekly use.
In terms of machines; my bandsaw is probably my most-frequently used machine. Followed closely by the drill press.
Again, it very much depends on what you want to do. Good luck in spending your £200.
TheUnicorn
21 Feb 2020
Bristol
personally I'd get a double bevel sliding mitre saw, I've just got a simple one without the slide and always regret not getting the upgrade, it would get a lot more use.
billw
The Tattooed One
26 Apr 2009
Sutton Coldfield, UK
As mentioned above it really depends on what you already have any what you want to make.
For £200 right now? A router is next on my list.
BenB
9 Nov 2020
Kingston
what do you already have tool wise?
Thanks for your response, I have a drill/driver, impact driver, table saw, jigsaw, mitre saw, router & home-made table, pillar drill, 3D printer, cheapo bandsaw, multi tool, pocket hole jig, I was looking at the mini circular saws (Worx etc) planers, sanders, lathes, and various gadgets
billw
The Tattooed One
26 Apr 2009
So the big gap in your kit is stuff to make surfaces flat. I'd think that looking there would be a good start. £200 is a bit light in that department for powered kit, but you could certainly get a lot of hand tools for that money.
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
a good diamond lap plate will always make u smile......nothing worse than blunt tools....
any change, think I'd get an expresso coffee machine for the shed......mmmmm
julianf
10 Nov 2017
devon
I find a thickenesser very useful. £200 is on the slim side, but iirc mine was £350 used and it's probably £1k ish new.
But then you need some sort of extractor also. They're not optional as, without, chips get under the blades and wreck the finish anyway.
Failing that, I'd buy a decent second hand compressor. The sort of thing that would be £450 new would probably be £150 used. A proper belt driven one, none of the loud direct drive ones.
Jameshow
4 Oct 2020
Bradford
I'd buy some planes no4 and no5
Even if you have some turn the worst ones into scrubbing planes.
I'd also buy a rip, cross cut, tenon and dovetsil saw. (Resharpenable.)
Also dovetail squares, veritas are ones are nice!
Any change????
Cheers James
Cabinetman
5 Jan 2017
Caistor lincolnshire
I needed a new set of handtools when I was in the States last year, I ordered just a very basic set from Axminster including delivery I seem to remember it was about £150, tenon saw, marking gauge, try square, marking knife, Engineers spike, nail punch, nice wooden handled screwdriver, one of those really good Japanese adjustable bevels, a mallet and a pin hammer. I already had the chisels and a number 4 plane. Then I fitted them all into a wooden rack to carry into the house for safety and warmth.
rope handle not fitted at this point.
Cabinetman
5 Jan 2017
Forgot, sharpening stone and Liberon honing oil as well, the Stanley number four was from a secondhand shop and fettled at home prior to me leaving. It really doesn’t have to be an expensive hobby this of ours. Ian
bowmaster
29 Nov 2014
Up to my neck in it in Sandy, Beds
Unless you have a need for a tool right now and rather than spend it for the sake of it - save your money until a project comes along that you need a specific tool for and buy it then......your money will then go to something you actually need rather than something that you think you need.
I don't know what you like making, but a tool that I find very useful is a scrollsaw - there are no end of things you can make with one of them.
thetyreman
4 Mar 2016
North West
I'd spend some of it on a quality combination square like starrett, you'll never regret that purchase, but think about what projects you want to make FIRST then get the tools needed, you might find there are tools you don't even need over time once you've made a few projects you'll get a feel for what's important and what isn't.
TheUnicorn
21 Feb 2020
Bristol
I'd second that
