What to do with this MONSTER ?
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Make the most of it and get it cut into veneer slices
Orraloon
18 Oct 2016
Blue mountains Australia
I have a large burl waiting to dry out a bit. Not quite that big but still rather hefty. A eucalyptus of some kind. My plan for it is to take a slice about 75mm from the flat end to make a small side table and then the rest should fit on my lathe for a large bowl.
Regards
Snettymakes
15 Mar 2020
Chorley
This is one I did a few years ago, I agree it’s not easy to think what you can use them for and this is just sort of a thing to put your keys in it’s about 500 mm long. IanView attachment 105433
that's beautiful, I love the contrast between the highly polished/finished surface and the hand gouged bowl 👌🏼
Cabinetman
5 Jan 2017
lincolnshire Wolds
Thank you, yes that was the idea, there was a defect just there which is one of the reasons why I took that out. There was another grotty bit on the edge which I cut off to make it the same width as my planer, then finished off with a smoothing plane. Ian
marcros
11 Feb 2011
Leeds
I have only used burr pen blanks and boards containing burry patches.
Is there a chance that it isn't burry inside and is quite boring? It is a question in general, it has always made me slightly hesitant with buying such things. I have only ever seen finished items and have no idea if the maker has discarded half of the burrs along the way in creating them.
Cabinetman
5 Jan 2017
lincolnshire Wolds
No Marcros, if you look at the surface on that one I made those brown splodges go all the way through and form the spikes on the outside surface – twigs I suppose you could call them. But there is often a sapwood area around the outside that is plain and can cause problems. You can see a bit of it on the end of mine near the scooped out bit. Ian
OldWood
1 Mar 2005
Edinburgh
I have an even bigger elm burr I paid £25 for - and then wondered when I did manage to get it home "how the hell am I going to use it?" Eyes bigger than ... etc.
There was a bit of hope that I would get some realistic suggestions in this post !
Ian, I'm wondering how you got such a good finish on that - and please don't tell us you have a lathe that can turn 500mm ! :ROFLMAO:
Rob
Cabinetman
5 Jan 2017
lincolnshire Wolds
Three posts back, cut a grotty bit off the edge which made it possible to put it over my planer, then finished it off with a sharp number 4 smoother.
Rob I have one that is not quite as big as the OP's but it’s shaped like a double humped camel, it’s been in the workshop for quite a while, very dry now and the bark picks off nicely when I’m bored lol. Far too big to go over the planer, but I still think I shall make a coffee table out of it, big holes running right through it from what would be the top makes it that bit more interesting I suppose?
Snettymakes
15 Mar 2020
Chorley
I love how being forced into to things by the medium can result in something so much better that you'd never have thought of otherwise
baldkev
29 Apr 2020
devon
Maybe chainsaw to take the top off, then set up a couple of rails and a router sled at the appropriate height to flatten? You could then spin the top that you cut off over, temporarily silicone some blocks / offcuts in place to prop it up fairly level and use the router sled to flatten the offcut too?
