Hi - I can't comment on the CFM's or what to look for regarding possible pump problems, but on the few occasions I've seen this done on TV and net, the biggest issue they always spoke about was making sure all of the air is expelled uniformly - the way I've seen it done the most often is by drilling small holes through a support slab of wood / ply the work rests on about the same size as the bag within a few inches, and on the underside of the slab joining all the holes in a routed crisscross pattern to allow all the air to get sucked out from the bottom of the press. You could technically route out the entire underside where the holes are as long as you leave a raised edge with slots in to allow the air to escape, this would allow maximum pressure exerted to the support slab from the material above.
Also adding some sort of perforated "sock" over the end of tube inside the bag to allow it to continue to function once the bag flattens out
This also works for items that require pressure on all sides as the atmosphere on the outside of the bag exerts pressure in every direction trying to equalise with the vacuum inside. (thanks Mr Oaks)
