What are these please?
Deadeye
21 Aug 2017
Buckinghamshire
Sorting out my late father-in-law's stuff. Three mysteries:
1. Is heavy and about 15cm long.
2. Is also 15cm long (ish) and has a numbered dial at the elbow
3. Is about 200 hard plastic balls, in 2 sizes - about 3cm diameter, solid apart from an 8mm hole to the centre, and about 12mm diameter, with a 5mm hole. I also have red ones the same. They don't seem to be to make garden canes safe, or to build 3-dimensional models of molecules.
Any ideas?
    242.8 KB
    245 KB
    245.7 KB
    244.3 KB
    245.5 KB
Sorry about the image repetition - all 5 are there but in the wrong place and the wrong order!
Mod Edit:- Images sorted.
First two items are a Tormek style (Sorby?) support and Jig for sharpening Wood turning Gouges on a bench grinder.
Balls look a bit like handles? I bought some similar ones for my drill a while back.
Does this help?
PM me if you would like a copy of the instruction sheet.
    198.9 KB
The balls are often used on the end of rods used for indexing or knocking out Morse tapers on a lathe.
Also in the 70`s they were hung on strings and called "Klackers" - great for breaking your knuckles......
