Michelle_K
I haven't been woodworking for very long. About two years now. I started off learning guitar making and I have learned woodworking at the same time. So there are a lot of processes I am still getting to grips with. Things that would seem easy and a skill I should have acquired far before ever attempting to make an instrument.
An example, squaring a piece of wood or flattening a face with out using sandpaper on a flat surface.
Usually when I have attempted to flatten something it has taken far longer then I have felt like it should. I am basing time scales on people I watch on YouTube etc. Intially I found I was ending up with slanted surfaces having one side higher then the other. Eventually I realised this was a combination of poor plane set up and incorrect pressure application.
Eventually I corrected this but I still slip every so often.
All of my planes have been second hand rusty old boot fair finds which I have cleaned up and tried as best as I can. I have flattened the soles as best I can on glass with wet and dry and checked hoping all was ok. This has cost me several packs of wet and dry.
Then the other day whilst at college I borrowed a class mates block plane which is new and good quality plane. I was flattening a piece of wood and with only two passes the wood was flat.
I thought it was a fluke so continued flattening several other pieces of wood and within a bit of time each piece was flat. The process was far quicker then I am used to and it was such a pleasure using a new tool. It got me thinking that whilst old planes are great for starting out,eventually it would be lovely to treat myself to some new chisels a hand plane and finally a brand new block plane. I know they will also need setting up but nothing like the restoration and set up of an old plane.
I just couldn't believe how easy it was and how the tool just did what I wanted it to do.
I have since again checked that the sole of my plane is flat and it is and it is set up correctly. It just doesn't seem to perform as quickly as the plane I borrowed!
Cannot wait for the future upgrades. I really like the look of that veritas plane which has the interchangeable frog. As for a block plane I used a lie neilsen once but that is a lot of money so maybe a veritas one one day. I don't know I just want it to be high quality. I had considered the quangshen planes as they are a little more affordable but they are just too heavy. After using one for an afternoon my wrist was so painful. As was my hand. Whilst using the block plane I had to keep stopping to rest my hand. I had great results with it but it hurt my hand to much. O
