There’s a lot of debate recently on this site (and others) around the subject of rust and its prevention on static hand tools – typically in unheated sheds and garages over the winter months.
This has led to the dreaded words “Dehumidification”, “Dew Point”, then “Psychrometrics”….. yes, “Psychr…..” put simply, it’s a fancy word for the science of the properties of air. It lends its name to a complex graph for dealing with the properties of air – its condition, or practically, “Air Conditioning”.
However, here’s an attempt to de-mystify all this by putting the complex bits we don’t need to one side and simplifying a few parts that we do need to the point where we can all deal with it without spending too much money or burning out too many brain cells.
Here goes. First, I’ll try to explain and isolate the problem from all the surrounding issues – then deal with how to come up with accurate measurements and interpret this to the point where people may devise their own solutions.
We all walk around in a gaseous soup that contains, among a lot of other things, particles of suspended water vapour. Although the extremes can be dangerous, as a species we can tolerate a wide range of temperatures and humidity – and they are linked together.
Put simply, there are two forms of humidity in air that can be measured: ‘Absolute Humidity’ – the amount of water vapour in a given volume of air by weight and ‘Relative Humidity’ – a variable amount of vapour expressed as a percentage of the potential containment at a given sensible temperature.
The former, Absolute Humidity (AH), can only vary if there is a fundamental change in the air’s properties, either through the addition of water – you boil a kettle and add steam – or you take some water out – it condenses on something. This is the basis of the whole Air Conditioning industry.
The latter, Relative Humidity (RH) will vary considerably; it is inversely linked to the sensible temperature of the air and as the temperature goes up, the RH goes down because higher air temperatures allow the air to contain a greater amount and the RH is a proportion of its containment. Conversely, if the air temperature goes down, the RH, which is inverse, goes up.
So, we know about humidity; how do we start to measure it?
If you’re still with me, and you want me to continue, let me know and I’ll show you how it can be done quite easily and most importantly, accurately with all the guess work taken out.
