Wera tools advent calendar £42.80
Essex Barn Workshop
11 Jul 2020
Loughton, Essex
at Amazon:
https://www.amazon.co.uk/dp/B08Q22CMG8?smid=A30DC7701CXIBH
Quite impressive contents, which apparently would cost £77.99 if bought separately
1x 6002 Joker, 8/10x141mm;
1x 350S PH1x80mm;
1x 355S PZ1x80mm;
1x 355 SL 0.6x3.5x100mm
1x 160i VDE SL 0.4x2.5x80mm;
2x 2050 PH00x40mm, PH0x40mm;
4x 2067, TX4x40mm, TX5x40mm, TX6x40mm,
TX8x60mm;
2x 2035 SL 0.4x2.5x80mm, 0.5x3.0x80mm;
1x 889/4/1 Bit Holder, 1/4"x50mm;
2x 851/1 BTZ, PH1x25mm; PH2x25mm;
2x 855/1 BTZ, PZ1x25mm, PZ2x25mm;
2x 867/1 BTZ, TX20x25mm,
TX25x25mm;
1x Bit-Check 7, Empty;
1x 9501 Zyklop Mini Bottle Opener; 1x 9458 Textile Pouch
Hook and Loop Fastener Strip, 200 x 30 mm
I usually end up recommending one of these in the pre-Christmas gift ideas vid. If you get one every year they can end up a bit ‘samey’ but usually good value for the contents you get, and can often be picked up a bit cheaper if you shop around. 👍
I wouldnt be waiting until the 25th..... by the lunchtime on the 1st id have opened it all up and stuck it in the truck 😆
Just ordered as a Xmas present for nephew who is just starting an apprenticeship (yep, they do still exist) in refridgeration.
I promised to buy him his tools if he stuck it out to the end.
Thanks for this, one Xmas present down, 28 to go. if only they just wanted tools....
Rob
