Well, I pulled the trigger on my first bandsaw!
HomeyJay
12 Jul 2019
Sidcup
After dithering for a long time and trying to decide between the Axminster 2305 and the Record Power BS300E, I chose the BS300E. I just felt that it was more solid than the Ax and the cast iron wheels just made it a smoother runner.
Anyway, after using the horrific factory blade for a while, I replaced it with one of the 3 RP blades (6, 4, 3 TPI) I got free with the saw and the cut was much better when using the 6TPI one but still not as smooth as, don’t laugh, my now returned Aldi saw! I think the blade on the Aldi saw was probably an 8TPI or higher job.
I’d really like to get a smoother cut if possible so I was going to order a couple of 3/8” blades from TuffSaws but I’m not sure which ones would be a decent general purpose blades. Would they be better than the RP blades in any case?
Can anyone help please? (homer)
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Tuffsaw quality much better, blade to use depends on how thick the wood you will usually cut will be, aim for 3 or 4 teeth to be in the wood at a time
HomeyJay
12 Jul 2019
Sidcup
Hmm, I don’t get that! If I’m cutting 4” thick wood, does that mean that I need a blade with 1 TPI??
Phil Pascoe
29 Jan 2012
No. It's a guide not a requirement - if you are cutting say 1/2" ply you should have 6 tpi minimum and maybe a 10 tpi max. Fewer it'll snatch, too many more and it'll clog. If you look at huge industrial saws they do have teeth that large ........... and motors to match. If you try starting a cut on a corner with a handsaw too quickly it'll jump - same thing. Once the cut is a little way in it smooths out - more teeth are in contact.
sunnybob
wysiwyg
11 Oct 2014
cyprus
email Ian at tuffsaws. tell him your machine, what wood you cut, and whether it is just straight or tight curves. He will tell you EXACTLY what blades to buy.
Simon_M
14 Mar 2019
Awbridge, Hampshire
As a guide,you can work with 3-24 teeth in the workpiece but 6-12 is better. So you could cut 1/2” plywood with 6tpi but not 6mm plywood with the same blade. A better blade for your 1/2” plywood would be 12tpi.
Using the wrong blade can be the difference between success and failure (more than machine or “skill”) and recognising that it’s time to retire the blade puts the “odds” in your favour too.
HomeyJay
12 Jul 2019
Sidcup
Just to let everyone know, spoke to [email protected] (what a gent), went over and collected a 16mm SuperTuff Fastcut blade and bl**dy hell - I felt that I'd been previously been cutting wood with a potato! This blade will basically cut anything at 10mm + and zip through it leaving a smooth finish. I'm honestly sooo impressed!
Many, many thanks to Ian at TuffSaws, you have another loyal customer!
woodbloke66
17 Sep 2018
Salisbury
Tuff saw blades are good and it's a revelation when you experience a decent blade for the first time, but don't forget there are other suppliers who provide blades equally as good - Rob
sunnybob
wysiwyg
11 Oct 2014
cyprus
My bandsaw blade buying experience is fairly limited, but of the three makes I have bought and used, Ian now gets all my repeat business (such as it is) =D>
Raymond UK
19 Jul 2018
South Yorkshire
Same here! It might have been you pointing me in the right direction but I've had 8 or 9 blades from Ian and I'm more than happy.
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
"....16mm SuperTuff Fastcut blade...."
I was wondering how many teeth per inch the blade has and going to the site didn't tell me because it is down for maintenance. So for the sake of my curiosity how many teeth does this blade have?
