Max Power
What type of welder would be best for welding the ends of the tyres on wooden cart wheels together?
I use two types one is solid steel about 45 x 12 mm , the other is a C shaped section of about 2.5mm thickness, which is designed to hold a solid rubber tyre onto the wheell.
Ive never welded, so easy to use would be good
