brianhabby
I may have to make some trestle tables with folding legs. They need to be about 5 feet long so I figured I would try to get hold of 10' x 5' sheets of ply. When I enquired from one of our local suppliers (Richard Williams in Deganwy) the chap suggested I use MDF instead of ply. I said that I would prefer ply primarily because of the weight, these things will need to be moved up and down stairs and need to be as light as possible.
When he came back to me with the prices he said he had been checking the weights of the boards and that the MDF weighs 53 kilos per sheet while the ply is 52 kilos per sheet. I find this hard to accept, that there is only one kilo difference between a 10' x 5' sheet of MDF vs ply.
What do you guys think?
Incidentally, I would have preferred to use block board because it is very light in comparison, but apparently it is not easily obtained and certainly not in the sheet size I need (unless someone knows differently of course).
regards
Brian
regards
Brian
