Wealden spindle tooling
Chippyjoe
21 Nov 2008
Norwich
Hi people,
Does anyone here use any of the spindle cutters from Wealdens?
Looking at their prices they seem quite a bit cheaper than Whitehill,and I was wondering if the quality was as good?
I have used their router bits before,and have found them to be very good and was hoping the same for their spindle tooling.
Also does anyone know if their cutters fit the Whitehill standard block?
Any help would be gratefull.
Mark.
The quality is very good, and the customer service is excellent (but you probably already know that)
I have a couple of bits and pieces by wealdons, the most expensive being a lock mitre cutter, can't fault it, very well made and gives me excellent results.
The Whithill knives are 6 mm thick and deflector (limiter) is 4 mm thick so there may be an issue with using the Wealdon knives and deflector (both 4 mm) in a Whitehill block
