Walk-In Wardrobe Build
So I have tweaked the design slight to accommodate some better features, and utilise the ceiling height a bit more.
Firstly, each side will have a divide in the centre of 8 drawers, meaning the draw width is only 80cm (taking away any strength issues with the drawers). The bottom two sets will be 25cm deep draw front, likely resulting in a 20cm draw for shoes and bags. Next two will be 20cm deep giving a 16cm draw depth. Finally the top 3 will be smaller and shallower drawers for small items.
This gives a maximum drawer height of 120cm including the carcas being 10cm off the ground which is comfortable. Allowing 120cm for hanging height on the two shorter rail spaces, this puts the total wardrobe height at 240 which also happen to be just shorted than a single board of MDF.
A third hanging space with 180cm length for coats and the GF's longer playsuit type clothes will allow space for two shelves at the base of the unit. I am going to use pull down rails so that my GF can get to the clothes, they also make putting clothes away a dream as they sit at the bottom of their motion.
This is the view without the drawer fronts on. I plan to use side fixing soft close draw runners. Some sort of plinth at the bottom and cornice at the top. Next I will look into which bits I should build in what order as given the tightness within the walk in area I will likely build sections and then final assembly in there.
Let me know any thoughts or better design tips please!!
I think interesting lighting pushes walk in wardrobes to another level.
Think back lit panels. LED strips in recesses etc..... if you want to obviously :)
I do want it! And I agree, it can really make it. The slight issue I have, is I was going to ask an electrician to help wire me in something off the switch inside, but the lights in there are 4 spots. It is quite a narrow space at 1.4m, so once the spots are on it will be pretty well lit! I need to think about how I could get some fancy lights in there tho.
Updated drawings. I was having a think about which parts I can build in my garage, and which would need to be done in situ given it is a bit of a narrow space. I came to the conclusion I could build a tall bookcase and a chest in the garage, then connect in situ and simply add a top section.
For those with experience, can you see any flaws in the strength of it? The top section will have some 2x2 batton attached to the wall, and screwed up into, plus into the two uprights and finally the bookcase.
