sawtooth-9
Having searched far and wide to find a Wadkin BZL lathe unsuccessfully, was lucky enough to find a Wadkin RS 6 which was up for auction within an hours drive from home in Sydney Australia.
The lathe is Pre 1956 and suspect it may be around 1945 - 1950
It was part of the pattern makers shop in a foundry which had ceased trading.
The lathe has had almost no use and showed no signs of wear. Looks like it has just sat there for the past 40 years gathering dust. The grease in the bearings had solidified and I suspect the bearings had been run dry so she sounded a bit grumbly. Someone had painted it sky blue with "house paint" !
Anyway, placed a number of bids and picked this little beauty up for a very fair price.
So far, it has been dismantled and the original Wadkin 3 phase motor rebuilt and fitted with new bearings.
Next job is to remove the spindle and replace the bearings.Whilst the spindle is out, will remove the speed change arms and re paint the headstock.
I have managed to find an epoxy enamel almost identical to the original Wadkin green
If there is any interest in the progress, I will learn how to post some progress reports and pictures.
