guineafowl21
Here is the machine:
And here is the 45-90-45 locking mech
There is rotational play in the arm even when the wedge locking lever is firmly located, and this is the case for all three positions, even the rarely used left mitre. So I think the problem is in the lever wedge, not the column cutouts.
The wedge does not bottom out radially, ie there’s a good gap between it and the bottom of the column cutout.
Using a marker pen, I can see the contact patch is at the lower edge of the wedge, so the play is at the top (greatly exaggerated in diagram - it’s about 0.1mm each side:
Should I file at the lower end of the wedge, or run it over a diamond plate, or something else?
